98path Posted May 5, 2006 Share Posted May 5, 2006 Hi guys I was thinking about putting a wire directly from the batt to my dist through a relay from switched off the key will this put too many volts to the dist and kill it or is there a possibility that it might run better with true battery power getting to the ignition thanks guys 98path Link to comment Share on other sites More sharing options...
XPLORx4 Posted May 5, 2006 Share Posted May 5, 2006 It won't put "too many volts" to the distributor, but you may set a check-engine light. I think the ECU shuts off power to the coil under certain conditions. Link to comment Share on other sites More sharing options...
98path Posted May 5, 2006 Author Share Posted May 5, 2006 thanks for the advice will post when I try and what happens 98path Link to comment Share on other sites More sharing options...
sw Posted May 7, 2006 Share Posted May 7, 2006 whats the problem? is it not doing something you want it to do? i personally would not do this for the above reason ie. engine shut down under certain conditions Link to comment Share on other sites More sharing options...
turbopath Posted May 8, 2006 Share Posted May 8, 2006 (edited) why not just have your relay switched by the factory power wire to the coil.... that way you won't get a SES light and it will turn on and off like it supposed to. If you REALLY want a beefy spark you can pick up a megasquirt and convert to a DIS system. Edited May 9, 2006 by turbopath Link to comment Share on other sites More sharing options...
98path Posted May 9, 2006 Author Share Posted May 9, 2006 O.k. guys I wanted a beefier spark but after looking at it and hearing yoursuggestions I'm scared off Link to comment Share on other sites More sharing options...
