solid snake Posted March 16, 2006 Share Posted March 16, 2006 My gas milage is around 12 mpg, which really sucks. before I go on, this is what I have replaced recently: Changed oil a week ago changed plugs new fuel filter pvc plug was replaced in september need to clean k&n filter, other wise is not very dirty upgraded to msd ignition about a month ago, need to change wire set had fuel system cleaned. Beside oxy sensor, which I will replace soon, what else can I do to increase mileage? Link to comment Share on other sites More sharing options...
sw Posted March 16, 2006 Share Posted March 16, 2006 he he he - he said milage and pathfinder in the same sentance. Link to comment Share on other sites More sharing options...
sw Posted March 16, 2006 Share Posted March 16, 2006 on a more constructive note... oxy sensor & wires should noticably help you can also try the coolant temp senor. the one that sends signal to the computer, changing the sensor for the temp gague wont do squat. this has to do with the computer having an acurrate idea of temperature and setting up a/f mixtures. Link to comment Share on other sites More sharing options...
94extreme Posted March 16, 2006 Share Posted March 16, 2006 clean/check your MAF. with all the goodies listed in your sig i am thinking your MPGs are about right though.. Link to comment Share on other sites More sharing options...
M in KC Posted March 16, 2006 Share Posted March 16, 2006 If you haven't and while you're in the area of the MAF you might get your tooth brush and carb spray out and remove the carbon off your throttle body. I don't feel so bad at 18+ mpgs. Then again you've got a few mods that will errode your fuel economy. Where are you driving mainly in the city, wheelin, highway, or some combination there of. Driving habits play a big role in fuel economy as well. I can get 4 additional mpg's in the wife's Maxima if I drive. Granted we get to where we're going a damn site faster if she's qualifying, I mean driving. Is Nissan on the NASCAR circuit? I didn't think so. I'll have to remind the wife, again. M Link to comment Share on other sites More sharing options...
Guest 95path addict Posted March 17, 2006 Share Posted March 17, 2006 It seems like a lot of people bring up fuel mileage , the vehicle I had before my pathy was a 03 jeep grand cherokee 4.0 6 cyl , now there`s a gas guzzler . although it did tow very well and had a super quiet cabin . So anyway I find the pathy`s are not to bad considering , Maybe it is the high fuel cost making it seem that way too . Link to comment Share on other sites More sharing options...
solid snake Posted March 17, 2006 Author Share Posted March 17, 2006 clean/check your MAF. with all the goodies listed in your sig i am thinking your MPGs are about right though.. i forgot to mentioned that I cleaned it also. Link to comment Share on other sites More sharing options...
solid snake Posted March 17, 2006 Author Share Posted March 17, 2006 If you haven't and while you're in the area of the MAF you might get your tooth brush and carb spray out and remove the carbon off your throttle body. I don't feel so bad at 18+ mpgs. Then again you've got a few mods that will errode your fuel economy. Where are you driving mainly in the city, wheelin, highway, or some combination there of. Driving habits play a big role in fuel economy as well. I can get 4 additional mpg's in the wife's Maxima if I drive. Granted we get to where we're going a damn site faster if she's qualifying, I mean driving. Is Nissan on the NASCAR circuit? I didn't think so. I'll have to remind the wife, again. M thanks for the t/b advise, will clean out this out sunday. "Then again you've got a few mods that will errode your fuel economy." What mods are you talking about, beside the larger tires. Link to comment Share on other sites More sharing options...
94extreme Posted March 17, 2006 Share Posted March 17, 2006 "Then again you've got a few mods that will errode your fuel economy." What mods are you talking about, beside the larger tires. the same ones i am reffering to would be my guess. 2" lift in front, 1 1/2" lift in the back, k&n air filter, flowmaster, 265/70/r16 a/t, pro comp 6" off road lights, msd 6a - not sure what is Link to comment Share on other sites More sharing options...
