yar1 Posted February 28, 2006 Share Posted February 28, 2006 hi,im probly going to get a 96 4x4,im pretty sure its an SE.it has the auto climate control if that helps 1.it has the good/tight LSD? 2.are the windows tinted?i didnt notice when i looked at it 3.it has the same t.case as the 1st gen X,right? 4.where can i find the specs for this truck/car?(HP,torque,ground clearance,etc) thanks! :help: Link to comment Share on other sites More sharing options...
Pezzy Posted February 28, 2006 Share Posted February 28, 2006 1. Not entirely sure what you are asking here - are you asking if it has LSD, or are you asking specifics on the LSD? 2. Are the windows tinted - I'd say go back & check... 4. Truck specs: http://www.carsdirect.com/research/nissan/...996/se/features Link to comment Share on other sites More sharing options...
deej Posted February 28, 2006 Share Posted February 28, 2006 I think there are a few typos on there Pezzy..........48 CCA battery? different tire sizes front and back? that's just a couple I caught. 1. LSD works fine, if it has it......look for the orange sticker on the rear diff 2. Windows are not tinted as a standard feature AFAIK, if they are tinted it was an aftermarket job 3. Not sure but probably not the same as the X 4.Click here for some specs but a google will give you a bunch more Link to comment Share on other sites More sharing options...
navygz19 Posted February 28, 2006 Share Posted February 28, 2006 it has the auto climate control if that helps Auto climate control? Isn't that only an LE/QX4 option for '96/97? Is it shift on the fly or All Mode 4x4? Link to comment Share on other sites More sharing options...
Pezzy Posted February 28, 2006 Share Posted February 28, 2006 different tire sizes front and back? Well that's interesting isnt it!! Link to comment Share on other sites More sharing options...
vengeful Posted February 28, 2006 Share Posted February 28, 2006 The only way to get an LSD on a 96 was with an XE level truck and the sport package. The sport package also added a few other options like power windows, air deflector, etc. The SE and LE came with reflective privacy glass, standard. The SE and LE had an auto setting on the climate control, that automatically adjusted fan speed when a desired cabin temperature was reached. It's not very effective, and I've ended up baking in winter. The transfer case has been the same for all Nissans for a very long time. It's the same TX10 as is in the Frontier, Xterra, Hardbody and WD21 Pathfinders. The rear axle is an H233b. Front is an R200. Your differential gear ratio will be able to be found by looking at the placard inside the drivers door. If the axle code is HG43, the differential gear ratio is 4.363:1. If it reads HG46, the ratio is 4.636:1. Factory Power output rating is 168 HP @ 4800RPM. Factory Engine torque rating is 196 ft-lbs @ 2800RPM. Ground clearance is 7.5 inches at the rear differential. You can find more specifications here. Link to comment Share on other sites More sharing options...
yar1 Posted March 1, 2006 Author Share Posted March 1, 2006 thank you all Link to comment Share on other sites More sharing options...
yar1 Posted March 9, 2006 Author Share Posted March 9, 2006 another question,can i use both front tow hooks on my car? in the manual it said not to use one of them but had an arrow pointing at both. Link to comment Share on other sites More sharing options...
Pezzy Posted March 9, 2006 Share Posted March 9, 2006 yeah, the manual says only use the passenger one... (for recovery) but I believe I have heard people have used either... Link to comment Share on other sites More sharing options...
yar1 Posted March 9, 2006 Author Share Posted March 9, 2006 is it a strong connection? or will it bend/break after the 1st hard pull?(like the skid plates) Link to comment Share on other sites More sharing options...
Pezzy Posted March 9, 2006 Share Posted March 9, 2006 No, I've used the pass side one a quite few times with no issues - it's the only recovery point I have on the front. Link to comment Share on other sites More sharing options...
yar1 Posted March 9, 2006 Author Share Posted March 9, 2006 ok,thanks Link to comment Share on other sites More sharing options...
lewisnc100 Posted March 9, 2006 Share Posted March 9, 2006 The only way to get an LSD on a 96 was with an XE level truck and the sport package. I thought the 96-97 Pathfinders had the LSD on the XE 4x4 w/ Sport Package, the LE 4x4 and the SE 4x4 w/ Off Road Pkg. Were the LE and SE LSD options not available until 97? Link to comment Share on other sites More sharing options...
yar1 Posted March 11, 2006 Author Share Posted March 11, 2006 yep^^,i found the orig window sticker and its an SE with OR package,including limited slip rear differrential ,btw,is it hard to change the fog light?tips?(besides not touching the bulb) Link to comment Share on other sites More sharing options...
IndianRider Posted March 23, 2006 Share Posted March 23, 2006 The only way to get an LSD on a 96 was with an XE level truck and the sport package. [/url] my 96 SE 4X4 auto has the LSD .. Link to comment Share on other sites More sharing options...
navygz19 Posted March 23, 2006 Share Posted March 23, 2006 btw,is it hard to change the fog light?tips?(besides not touching the bulb) What do you mean? :confused: Like remove the stockers and replace w/ aftermarket's? Link to comment Share on other sites More sharing options...
vengeful Posted March 23, 2006 Share Posted March 23, 2006 I thought the 96-97 Pathfinders had the LSD on the XE 4x4 w/ Sport Package, the LE 4x4 and the SE 4x4 w/ Off Road Pkg. Were the LE and SE LSD options not available until 97? I thought the LE and Off-Road Package on the SE started in 97...my mistake. Link to comment Share on other sites More sharing options...
vengeful Posted March 23, 2006 Share Posted March 23, 2006 btw,is it hard to change the fog light?tips?(besides not touching the bulb) Changing the fog light bulbs is relatively easy. All you need is one wrench to take out the fog light housings and the bulbs just kinda twist out. Link to comment Share on other sites More sharing options...
yar1 Posted March 24, 2006 Author Share Posted March 24, 2006 how do i program the homelink garage door opener? ive tried the directions but it doesnt work.any tips? is it possible my garage door fob wont let the homelink pick up its signal? Link to comment Share on other sites More sharing options...
XPLORx4 Posted March 24, 2006 Share Posted March 24, 2006 Follow the homelink instructions for programming the button (i.e. hold down your regular remote button and the homelink button together, etc.) Then, go to your garage-door opener motor, and press the "learn" button (usually behind one of the light covers) which tells the opener it's ready to learn a new remote signal. Go to your vehicle and press the homelink button you just programmed until you see the garage door opener operate. Link to comment Share on other sites More sharing options...
