How to remove door panels for speaker access?
leojharris
hello ...
i've removed door panels before ... but for
the life of me, i can't seem to get the panels
off of my 95 XE.
thought they'd just pop off after removing door
handle, but no go ... tore one mounting bracket
through the particle board before deciding to
ask around.
i want to put some speakers in.
thanks for any assist.
.joel.
Not sure how similar they are to my '87...
But I just used a standard panel popper tool - it is like a big-A flat screw driver with a nothched tip. Slide the U around the christmas tree and pop it out.
Sometimes you can get them out by just pulling on the panel, but often (especially if the panel ever got wet) the tree will pull through the fiber board. So using the tool is good insurance.
Where are you at? If shipping is reasonable, it may be cost effective to loan you my tool.
Edited by mws
or you can probably go to your local ricer/stereo shop and buy one for like $5, or from crutchfield for like $10 (ripoff). or if you want the darn bestest door clippy remover thingy you can get this one! :)
http://buy1.snapon.com/catalog/item.asp?P6...ore&dir=catalog
i've pulled my door panels off and on a bunch of times and a real wide bladed slotted screwdriver works fine for me.
Edited by statikuz
