MiSh Posted December 9, 2005 Share Posted December 9, 2005 did some heavy 4x4ing on the weekend and heard a creak in the frount end. Got out and had a look for posible broken tie rod. All was good so i got back in the car. On the way home i took a corner to quick and heard a snap. Got out and i saw the right hand tire on a mega lean. But to my suprise it wasnt the tie rod but the bolt that conects the centre link to main suspension thingy had been sheared(technical term).Will all i need be a new bolt and all the bushes. Is it worth taking it into a suspension shop as all my other bushes are shot anyways. Get them to do it all at once Link to comment Share on other sites More sharing options...
k9sar Posted December 9, 2005 Share Posted December 9, 2005 (edited) hmmm... yo have me confused. There are no bolts on the centerlink. Unless you have a steering stabalizer (horizontal shock), you have 4 connect points, all of which are ball joints (each side to tie-rod, pitman and idler). If one of these has 'snapped', you are probably looking at a new centerlink (if at the pitman or idler) or a new tie rod end. Edited December 9, 2005 by k9sar Link to comment Share on other sites More sharing options...
madhatter_xe Posted December 9, 2005 Share Posted December 9, 2005 FRONT Link to comment Share on other sites More sharing options...
k9sar Posted December 9, 2005 Share Posted December 9, 2005 (edited) FRONT dude... he was spelling it for you canadians... 'frount' 'eh? next you'll be making fun of all his bushes being shot Edited December 9, 2005 by k9sar Link to comment Share on other sites More sharing options...
Simon Posted December 9, 2005 Share Posted December 9, 2005 Why would someone shoot someone else's bushes?!?!? Who would have such a hate on for shrubbery?!?! If I were you, and you have the inclination, do it yourself. The work is labour intensive....so you're paying more for elbow grease than for parts in this situation. I would to all of them at once though, get it done and over with. Link to comment Share on other sites More sharing options...
madhatter_xe Posted December 9, 2005 Share Posted December 9, 2005 dude... he was spelling it for you canadians... 'frount' 'eh? well in that case his pronunciation is dead on...just needs to work on that American spelling... :o Link to comment Share on other sites More sharing options...
Precise1 Posted December 9, 2005 Share Posted December 9, 2005 I'm thinking he means one of the control arms... Yes, have them check the other bolts, and when they do that, put in new bushings. Having them check/replace the ball joints is also recommended as they will be right there and it won't cost much more than the parts. Specify you want QUALITY ball joints with zerk fittings so they can be greased. I believe Moog's are like that. B Link to comment Share on other sites More sharing options...
MiSh Posted December 12, 2005 Author Share Posted December 12, 2005 this is the broken bolt Link to comment Share on other sites More sharing options...
exodus_68 Posted December 12, 2005 Share Posted December 12, 2005 I can't quite tell from how small it is Mish, but if you had broken the bolt that attaches the drag link to the Idler arm you would only be steering one wheel. Can you send me a photo to my phone and I can maybe tell you what is broken? Justin Link to comment Share on other sites More sharing options...
