tkpath Posted December 1, 2005 Share Posted December 1, 2005 (edited) Stock 2001 Path SE with manual trans. Has Bridgestone Dueler HT (scary in winter/wet) 255/65/16. Time to replace. Want the Dueler AT or AT Revo OR the Mich LTX M/S. Questions: 1. I know it's been asked but can I, without any further mods to car, put 265/70/16s on? 2. Bridge AT Revo v. Mich LTX .. any thoughts. THANKS Edited December 1, 2005 by tkpath Link to comment Share on other sites More sharing options...
Filthy Luker Posted December 1, 2005 Share Posted December 1, 2005 Those listed above are not winter tires. Try Bridgestone Winter Duelers or Blizzaks, or the Nokian Hakkapeliitta SUV. There aren't better winter tires period. Link to comment Share on other sites More sharing options...
DJ Dank Posted December 1, 2005 Share Posted December 1, 2005 Yeah I second the Nokians if you want a good dedicated winter tire. Well this is my third winter with these REVOs and they are still great but I just rotated them maybe a couple of months ago. The fronts originally were more worn and now that they been rotated to the rear, they spin in the snow/ice a lot more easily than previous winters where that would almost never happen. Link to comment Share on other sites More sharing options...
abomb1 Posted December 1, 2005 Share Posted December 1, 2005 I was very happy with my BFG AT's in the winter. I don't have experience with the 2 tires you are looking at though. You might have a problem fitting a 265mm wide tire on the stock wheels without hitting the strut. Do you have much room between the strut and your 255mm wide tires you have now? Link to comment Share on other sites More sharing options...
tkpath Posted December 1, 2005 Author Share Posted December 1, 2005 I will use these tires year round .. sorry about the confusion. Had ATs in the past and there were great around here (WDC). I'll check the clearance wrt the strut. I seem to recall others trying this 'upgrade' and reporting no problems but I'll check nonetheless. There just are not many preferable (to me) tires available in stock size. Thanks for the replies so far. Link to comment Share on other sites More sharing options...
DJ Dank Posted December 1, 2005 Share Posted December 1, 2005 Also did you check out the reviews at TireRack.com? Link to comment Share on other sites More sharing options...
tkpath Posted December 1, 2005 Author Share Posted December 1, 2005 I did check those DJ. Not as many Pathy responses as I would like .. so, here I am! Link to comment Share on other sites More sharing options...
tmorgan4 Posted December 1, 2005 Share Posted December 1, 2005 I have 265/75/16 BFG's on my '00 and have a few mm of clearence between the strut and tire. You will have to either cut or remove the front plastic wheel well though. Link to comment Share on other sites More sharing options...
tkpath Posted December 1, 2005 Author Share Posted December 1, 2005 If I want to go to the Dueler AT Revos and not flunk the 'tire conversion test' (something about diameter and brake failure) on most tire websites, I think I'm looking at: 245/70/16 or 255/70/16 .. as I plan to use these tires year round in the WDC area, any thoughts as between those two tire sizes? Link to comment Share on other sites More sharing options...
yowzaeric Posted December 2, 2005 Share Posted December 2, 2005 I had the Michelin's on my 04. They were a great tire on road/rain and in the sand... Sucked wind in any type of mud. Not bad in the snow- I never got stuck but I didn't run in anything too deep. Way better than the stock duelers (then again I've had drag slicks get better traction than those) They rode quiet and in the 13,500 miles I put on them there wasn't any wear so to speak. Link to comment Share on other sites More sharing options...
tkpath Posted December 2, 2005 Author Share Posted December 2, 2005 Thanks for the note on the Mich's. That's what I've been hearing on them. Way, way better than the OMEs but maybe not the all around capability of the Bridge ATs. Link to comment Share on other sites More sharing options...
DJ Dank Posted December 2, 2005 Share Posted December 2, 2005 Also Bridestone fairly occassionally does like $75-off specials etc...After price checking the Revo's everywhere, Tire Rack had the best price until shipping got figured in. I ended up going to Costco and they priced them the same but had to order them also but shipping of course was on them. I ended up getting them for $130 a piece, mounted/balanced. Slightly more than the BFG AT KO's. Link to comment Share on other sites More sharing options...
tkpath Posted December 2, 2005 Author Share Posted December 2, 2005 DJ what size are you running on your Path? Did you have to (or did you) mod the car for the tires in any way? Link to comment Share on other sites More sharing options...
DJ Dank Posted December 2, 2005 Share Posted December 2, 2005 I'm running 31'sx10.5 and they're 15". They fit fine with very minor rubbing at full turn. Link to comment Share on other sites More sharing options...
