tkpath
    01 Path
    Rarely Go Off-Road
tkpath's Achievements
NPORA Regular (2/5)
  1. It's a nasty/alarming sound. I know it's supposed to be the release bearing from all I've read but it has a bit more resonance to it than I'd like (without knowing for sure it's that bearing). Pain to get to a decent dealer so I do appreciate the good guesses.
  2. '01 SE, manual transmission, 104k miles. Latest clutch has maybe 60k on it and rebuild trans maybe 40k on it. Got a little chilly in the NE recently. Car cold. Clutch depressed, first gear selected, start car .. noise. I guess it was a slight howling sound but almost like a pump failing as well. Went down a few days later, same start up drill, same sound regardless of gear selected while parked .. then slipped stick to neutral with clutch released (pedal NOT depressed) and, voila, noise gone. Depress clutch pedal .. noise back. If you drive a bit and restart, no sound but after a bit of downtime, sound back at start up. Any and all input appreciated. Tom
  3. Had the dreaded Pathy radio issue. Radio and CD player is one unit. Remove. Go to google, type in pathfinder .. radio .. repair and one of the first hits will be a guy who advertises on Ebay (in California). You send him the whole unit plus about 120 and he send the thing back to you. Did it a couple of years ago and it's worked find since.
  4. Clutch slipping? Are you thinking that perhaps it's catching late .. throwing power to rears in a sudden fashion? I'll check. I don't think that's an issue .. haven't noticed anything particularly alarming on dry pavement. Just seems that goosing it doesn't help me. Came from a man. transmission Ford Exp Sport on which the Bridgestones made a world of difference on wet pavement.
  5. Always had good luck with REVOs, generally happy with them on the Pathy. However, in the wet and on (even a) slight hill .. the back end wants to slip out no matter how much I play with the clutch/gas). Do I need a little weight back there even for non-winter driving?
  6. wrt this pen like bulge in the fender .. anyone try grinding it off or at least thought about it? I haven't looked inside the fender but just thought I'd ask if it was worth tackling.
  7. Hmmm, maybe this is why Tire Rack was recommending 245 70 16s to counter any complaints they might get about 'rubbing.' Thanks for helping answer the question 'where's the rub.'
  8. Only when backing up? Maybe it's time to count the pets. Thanks for the input.
  9. Thanks everyone! Maybe we can put this in some sort of permanent file for all of us poor folks who got stuck with the stock HTs. 255 70 16 it is. I'll see what I can do about getting the Tire Rack guy to go against his conscience. And tecciball .. sorry about the install problems (sure it's not because they're rubbing(!!!haha)).
  10. Really. I did review the archives but couldn't answer my question, which is .... 2001 Pathfinder SE manual with the OEM 255/65/16 (the size excluded by AT tire makers), no mods/lifts, etc. Called Tire Rack. They will sell me Bridgestone Dueler AT Revos size 245/70/16. Questions: 1. I THINK I saw on this forum where folks were putting 255/70/16s or 265/70/16s on the 2001+ SEs (not Infinitys or LEs which I believe actually come made for a large/normal tire). Tire Rack rep said those sizes will rub/cause speedo issues, etc. Anyone experience this? 2. Dueler AT v. Dueler AT Revo ... is the Revo just hype? I've had Dueler ATs in the past and was happy with them. Most interested in wet/snow traction. Thanks everyone.
  11. It was the ridiculously expensive charger they sold to me (Verizon) when I purchased phone last August. I think it was a 'verizon' charger .. probably meant to be the solution to any car lighter but I'll check. Any better brand of charger out there? Simon noted he has a Treo .. what charger do you use? Thanks all .. I have my EE son visiting with me so I'll see if I can talk him into performing some of the steps noted above. In the meantime, guess I'll just be careful inserting the charger.
  12. OK. 1. Found the other socket. I should look around the car more often, wonder what else is there. 2. Inserted phone and charger into other socket .. worked fine until I tried closing the armrest cover. Blew fuse. 3. Replaced fuse. Tried dash socket. Worked fine if I inserted the charger only part way (enough to activate charger and charge phone). However, when I pushed the charger into the socket all the way, it blew the fuse. Charger has two metal springs on either side of prong but at tip of prong it has a retractable metal nipple .. about 1/4 inch max. Any idea what is happening when I push the charger into the socket all the way? I guess when I closed the armrest cover in 2 above I created the same effect.
  13. Thank you sir. Let me run through the fix-it protocol and see if I can narrow it down. Whoever said the Treo will not draw 15 amps has got to be correct. Probably is the socket .. I checked all connections when removing the CD changer today so maybe the fix is in. So to speak.
