Precise1 Posted November 16, 2005 Share Posted November 16, 2005 I think his project has grown since he has first considered it. I'm sure he has learned a lot on the way which has lead him to this point. I think he would have jumped on an available SAS kit in the begining if there was one. Seriously, how many people have the know how, resources and time to figure out an SAS on their own ? I agree with you that it would be a better idea from the start, but it takes a lot more than just saying 'just SAS it'. If he went with leaf springs, would you say 'why didn't you coil over it' ? Where does it end ? Everyone has to start somewhere, and I give him credit for tackling the 2wd to 4wd conversion alone. Lets see where it goes, and help where we can. B Link to comment Share on other sites More sharing options...
87pathy Posted November 17, 2005 Share Posted November 17, 2005 Did Calmini say it was going to be a leaf sprung suspension? Just asking cause the pic they show is of a D21. i thought i saw one on coils before but maybe i was wrong. Link to comment Share on other sites More sharing options...
SC88Pathy Posted November 17, 2005 Share Posted November 17, 2005 Did Calmini say it was going to be a leaf sprung suspension? Just asking cause the pic they show is of a D21. i thought i saw one on coils before but maybe i was wrong. I think you might be thinking of their fronty SAS, so far all pictures of the SAS'd pathy have shown leaf springs. Hmm just looked at there web page I thought there used to be a seperate SAS Pathfinder in their project page but now it's just the sas hardbody. Shouldn't matter too much though seeing as how the hardbody and pathfinder front half's aren't too different. As long as it's a well designed leaf spring suspension with good shackles it should have a good amount of flex. Obviously it will be nowhere near as good as coilovers, but it should be better than the IFS, maybe... Link to comment Share on other sites More sharing options...
SteeevO Posted November 18, 2005 Share Posted November 18, 2005 i know this isn't really the place but just a FYI.. If the kit were avaliable b4 i started the whole project i would have done an SAS instead...however it still isn't out so.. IFS for me.... Link to comment Share on other sites More sharing options...
FLApathy Posted December 11, 2005 Share Posted December 11, 2005 (edited) i was over at NOR and found this X with the calmini sas kit, about half way through the first page he says its the calmini kit and yes i know that theres a difference between an X and pathy Edited December 11, 2005 by FLApathy Link to comment Share on other sites More sharing options...
Vsicks Pathy Posted December 11, 2005 Share Posted December 11, 2005 (edited) i was over at NOR and found this X with the calmini sas kit, about half way through the first page he says its the calmini kit and yes i know that theres a difference between an X and pathy I could not help but notice the huge bend in the drag link. Seems Calmini have a weak point built into their set up. Other than that, the job looks pretty easy. I will check back to see how the bracket lining up issue pans out. Edited December 11, 2005 by Vsicks Pathy Link to comment Share on other sites More sharing options...
87pathy Posted December 11, 2005 Share Posted December 11, 2005 i read the whole string, what i can't believe, is that the guy put everything in, complete without checking his castor angle.. that should have been the first thing he did before tak welding the first bracket -alcohol- oh well, live and learn. looks sweet in the end. you could easily make that work on a pathy. I would have conserns about the xfer case support. you wouldn't ever be able to lift it more, i had to make a custom xmember to go above the drive line so it wouldn't hit it. Link to comment Share on other sites More sharing options...
deadkennedys Posted December 11, 2005 Author Share Posted December 11, 2005 looks pretty sweet. wouldnt mind having a wd22 with an sas kit myself Link to comment Share on other sites More sharing options...
