Mr. Pickles Posted October 16, 2005 Share Posted October 16, 2005 First off... sunovamuthafukingodampieceofishtkismya$$nogood.... So I'm sitting in the rain, fitting some angle iron to try and make a mount for my grill guard, and the flashlight hits... grease. As in, a freshly torn boot. Looks very fresh, no dirt or anything. Soooo... how bad does it suck to pull this. I'm looking at 3 options: send it in to get done and be incredibly broke due to low funds, do it myself and be absolutely frustrated, or roll one of those temporary boot replacements such as on AC. Who has some input? I'm looking at a run in 2 weeks and it seems like every time I'm ready to play, something breaks. I sick and tired of this bull_shrimp. Link to comment Share on other sites More sharing options...
94extreme Posted October 16, 2005 Share Posted October 16, 2005 yeah a bit of pita.. more time consuming then anything... i think there are a few threads about this on here.. you have to take off the caliper and undo the bjs then undo the cv axles.. not too bad but i had a heck of a time separating the join on one of the axles.. good luck, diy and save the money.. better get started now.. you should be able to do it in a few hours.. Link to comment Share on other sites More sharing options...
solid snake Posted October 16, 2005 Share Posted October 16, 2005 Yeah I had a mechanic friend of mine to help me in replacing the inner boot, but it was a pita. it took a couple of hours, and guess what? I have to replace the drivers side too Link to comment Share on other sites More sharing options...
Mr. Pickles Posted October 16, 2005 Author Share Posted October 16, 2005 AC boot is on the way just in case or for a backup down the road. How many RPM's is duct tape rated??? :secret: Link to comment Share on other sites More sharing options...
revgolem Posted October 16, 2005 Share Posted October 16, 2005 have you looked into just replacing the entire axle? if you turn in the origional for the core charge, it's usually pretty cheap and a HECK of a lot easier and really not that much more in cost. and that way you will know that the joints are good as they tend to get pretty worn depending on how ling you've been running with torn boots. the temp 'split type' boots are ok, but you'll be replacing them sooner than you would want to. Link to comment Share on other sites More sharing options...
MaritimeMan Posted October 16, 2005 Share Posted October 16, 2005 Duct tape is rated at 100 mph. Not sure what that translates into in radial velocity, but I'd imgaine it would hold. Link to comment Share on other sites More sharing options...
Mr. Pickles Posted October 16, 2005 Author Share Posted October 16, 2005 Well, it happened sometime in the last few days, I think between Thurs.-Sat. I just had it in the shop Wed. for tires, and it didn't come up. I was just crawling around underneath a few days before and specifically looked too. For now, I'm just gonna wrap it in duct tape too keep it clean till that boot comes, just in case I need to drive somewhere quick. In the meantime, we'll be a 1 vehicle household. Link to comment Share on other sites More sharing options...
