dangerously low oil pressure
madhatter_xe
Does anybody know if I can get to the oil pressure regulator bolt without dropping the pan?
I installed an oil pressure gauge the other day and noticed, in horror, that when my truck is warmed up the pressure drops to 0 psi at idle. This is not good.
I am hoping 'maybe' the spring on the oil pressure regulator was jarred loose from hard wheeling or maybe my shady FRAM oil filter is the culprit. :shrug:
I'm not really in the mood to have this engine rebuilt or buy a new one.
Edit: I should add, after some wheeling, my OP warning light blinked a few times, when I checked the sending unit it was full of water and dirt, so I figured that's why the light came on a couple times. So I yanked the sending unit and installed the oil pressure gauge instead.
Edited by madhatter_xe
well I pulled the sending unit, so there are no more wires to send false readings. Now I have an oil pressure gauge, which is reading 0 psi at idle.
It may not be easy to get at regardless, but I'm wondering if I need to drop the pan to get to the oil pressure regulator bolt.
yeah, i'm going to do an oil/filter change tonight. I bought a Valvoline filter, but everybody keeps talkin bout how great NAPA is, so i'll give it a go.
The hose is what came with the gauge....it's probably about 5ft. from the fitting in the engine to the gauge under my dash.
I guess I'll see how it goes after the oil change, I'm putting some STP oil treatment in too.
Did you cut the presure line down to only what you need or is that 5ft the total length that was supplied in the package? Where possible, cut off any extra line you have and reconnect it to the gauge/block. (allow for engine/body movement)
Yesterday I bought a new set of fittings for my other trucks gauge, and it came with 6ft of plastic tubing..
Like 88 said, false readings can come from a hose that is too long. Also, check again for kinks.. not just ones that are there now, but also for any that have been "worked out".. because the hose could still be compressed a little where the kink was.
I changed the oil/filter last night it has been holding steady at around 5-10 psi at idle. I think the problem was also that i was checking the psi while the truck was in gear, should've been checking it in neutral, with no load on the engine. It does dip lower than I'd like but I think the minimum is 5 or 6 psi so it should be allright.
Thanks for the help.
