Matthew Posted August 16, 2005 Share Posted August 16, 2005 To put these headlights in my '02 Pathfinder, would I only need to buy the bulb; does that fit correctly? Or would I need to buy something to install them. Link to comment Share on other sites More sharing options...
02silverpathy Posted August 16, 2005 Share Posted August 16, 2005 Just the bulbs, but if you re wire them like 88 shows in one of his pin-ups, they are incredible...i did this to my 98 making high and low on a new circut with larger wire and seperate relays and they are as close to HID brightness without the cost as you can get...color temperature isn't bad either!!! Link to comment Share on other sites More sharing options...
Trainman Posted August 16, 2005 Share Posted August 16, 2005 Before you go whole hog on lights , check this site out: Daniel Stern Lighting Click on the Tech link for info like these below: Some info from this site: What's the Scoop on Osram-Sylvania CoolBlue, Philips BlueVision, Sylvania Silverstar, and Other "Blue" Bulbs From Reputable Manufacturers? You're asking about the current crop of bulbs, widely available in auto parts stores, with a blue absorption filter on the bulb glass, which is there to make the light look whiter. These bulbs are safe and legal, though not particularly advantageous, to use in your car. It Sounds As If You Don't Think These Are The Best Choice For Maximizing My Headlamps' Performance. What Is? For those who want the best possible performance from their headlamps and are more concerned with their ability to see rather than the appearance of their headlamps, the major bulb companies offer optimized bulbs WITHOUT the light-stealing blue coloration. Sylvania Xtravision (in the pink-and-black package), Osram Super and SilverStar(outside North America only!); Philips High Visibility (North America), Premium and Vision Plus (outside North America); Narva RangePower are the ones to look for. On Super Whites: Superwhites Claims ("55w = 85w", etc.) made for "Superwhite" type bulbs are very misleading. They simply aren't true. Here's the full scoop! CLAIM: "SuperWhite" bulbs produce 85W of light from 55W of electricity REALITY: "Superwhite" ("Hyperwhite", "UltraWhite", "Platinum", etc., basically any bulb advertised as being "whiter" than normal) bulbs produce more glare and less seeing light than standard bulbs. The "55W = 85W" type claims are a sham. Here's how these kinds of pretend wattage numbers are cooked-up: The blue or purple filtration coating on the glass tints the light so that it is "whiter". Most bulbs that actually produces more light (i.e., higher-wattage bulbs) also burn with a whiter color than standard-wattage bulbs. With these color-coated bulbs, only the light color, and not the actual light output, imitates a high-power bulb. There is no seeing advantage to "whiter" light, though some people seem to think that others will look upon headlamps so equipped and go "Wow, cool!". Why they believe anyone else cares what color their headlamps are is anybody's guess. A major reason why many people find many US-specification headlamps in need of upgrading is because many such headlamps have very low levels of foreground light, which creates a "black hole" on the road in front of the car. There's often insufficient lateral light (left and right) to see critters or people before they run into the road. The "hot spot" creates a narrow tunnel of light that disappears "out there somewhere", with no visual cue to where the beam (and therefore the driver's seeing range or "preview") ends. But these headlamp performance aspects are governed by the optics of the lamp, not by the color of the light. Bulbs with blue or purple tinted glass never improve the performance of your headlamps. They may leave it relatively unchanged, or they may severely reduce it, but they never improve it. CLAIM: "Our bulbs produce the whitest and brightest light on the road!" REALITY: "Brightness" is like "Loudness". It's a subjective perception. Is Metallica " louder " than Bach? Most people would say so. That's why audiologists use an objective measurement, Sound Pressure Level, rather than subjective quantities like "volume" and "loudness". And so it is in the science of light. "Bright" and "Dim" are subjective perceptions. Intensity, measured in any of several precisely-defined and scientific ways, is the only real way to gauge or compare output of a light source or performance of a lamp equipped with a light source. A 4-watt flashlight bulb dipped in the purple coating applied to these tinted headlamp bulbs would look "whiter", and might look "brighter", but would produce less light. And so it is with these headlamp bulbs. The reason why the scam fools people into thinking their headlamps really work better has to do with the interaction of light that is tinted blue (to any degree) with the human eye. This kind of light has been shown in rigidly-controlled scientific studies to create almost 50% more glare than untinted light from a bulb with clear glass. But there's no 50% increase in seeing to go along with the extra glare; there's no increase in seeing at all, and in most cases there is a moderate reduction in actual seeing light. More glare, less seeing: Everybody loses. CLAIM: Many of these bulbs are sold with claims of specific "color temperature" (e.g. "5000K"). Often, these ratings are accompanied by text to the effect that higher color temperatures are "close to natural daylight". REALITY: Color Temperature is a real measure, but it is being improperly used to claim improved seeing. Legitimate bulb manufacturers do catalogue the color temperature of their products in technical literature not usually distributed to consumers, because scientists and engineers can use it as a convenient proxy indicator for filament luminance. But it has no predictive value for the performance of an automotive headlamp, nor does it indicate how well you'll be able to see. The idea being sold with these "Kelvin ratings" is that the light is closer to natural sunlight. As with many sales claims, there is a small kernel of truth here, but it's cancelled out by the smoke and mirrors. Noonday sunlight does have a much higher color temperature than most uncoated headlamp bulbs, but there are a great many other differences between sunlight and headlamp light, as well. Not only that, but the Color Temperature rating is really valid only at extremely high light intensity, such as that produced by the sun. At the lower intensities produced by most electric lamps including headlamps, the rating no longer says much about the light, but only allows a limited, referential comparison of different light colors. The tinted bulbs' poor imitation of the color of sunlight does not mean that the headlamp output is "just like sunlight", or anything even close. As with the wattage equivalence claims discussed above, a color-based comparison is being used to imply an intensity and seeing-ability comparison that does not exist. This also addresses the related claims that CLAIM: "I've got pictures that prove the brightness difference!" REALITY: Photographs, film or digital, cannot accurately represent the intensity of a light or lamp, because of the many significant differences in the perception of light by the human eye vs. the camera. By simply adjusting the exposure settings or white balance, virtually any bulb or lamp can be "shown" to be superior to virtually any other. BOTTOM LINE: The laws of physics are the laws of physics. They don't bend even for the highest-paid advertising agency. There is no way to get "85 watts of light for 55 watts of electricity." Tinted bulbs aren't better. Link to comment Share on other sites More sharing options...
statikuz Posted August 16, 2005 Share Posted August 16, 2005 yeah, the sylvania silverstars apparently aren't all that great, not that i'm one to talk because i fell into the trap of PIAA bulbs, but like he says, the ones to get are the xtravision, or philips vision plus... some come in some types of bulbs and not others, i'm not sure which # of bulb your pathy takes... Link to comment Share on other sites More sharing options...
mws Posted August 17, 2005 Share Posted August 17, 2005 Awesome post, Trainman. In my opinion, flooding the forum with facts is always OK! Link to comment Share on other sites More sharing options...
02silverpathy Posted August 17, 2005 Share Posted August 17, 2005 without sounding like some sort of rebutal...there is no other lamp that you can simply install that simply looks as clean coming from your housing as these silverstars. i absolutly hate that dimmed yellowish white "like a stick of margarine" like this guys light bulb. :idea: these lights may not actually provide more lumins or have the same dispersal as another light but since i went throught the lengths of putting my lights on their own circut with 12 gauge wire they are bangin' white and look like the light should be burning your hand in the beam!! the number of ricers out there with those sickly blue like "k-mart" look is more than enough factual reason not to buy bulbs that just emit blue light. on another note i am still trying to get my buddy to pigtail his aftermarket HID's in his beemer to my pathy to see what my housing will do with the light. Link to comment Share on other sites More sharing options...
statikuz Posted August 17, 2005 Share Posted August 17, 2005 your housings will pretty much butcher any effect you might get from HID lights... they need a whole different type of reflector to work properly. read up on the stuff on that lighting site, it's all pretty good information. Link to comment Share on other sites More sharing options...
