100K is just around the corner...
vengeful
I am starting to plan and source parts for my week long 100,000 mile (well it'll be a little premature at 97,800, but oh well) servicing.
I already know that I need to get the following:
Timing Belt
Camshaft Seals
Crankshaft seals
Water pump
V-Belts
Hoses
Wheel Bearings (mine are so shot its not even funny...)
All fluids and filters
Front brake rotors (beyond resurfacing at this point, have)
Anything else you guys think I should do at this point?
Idlers/tensioners?
etc?
The timing belt interval is 105K, FYI. So you're really about 7,500 miles premature.
Other things you should be checking or servicing include the following, if they have not been recently changed:
accessory drive belts (2 serpentine: AC and fan/alt, 1 V-belt: P/S pump)
rear brake drums and shoes
dist cap/rotor
plugs
plug wires
I assume by "all fluids" you mean:
engine oil
ATF
t-case fluid
diffs
brake fluid
coolant
power steering
Edited by XPLORx4
Yeah, 10-4 on that all fluids deal...
And, I want to get all of this major servicing out of the way before I head back up to school, as it will be getting cold rapidly once I'm in Rochester, and there's a good chance I'll be driving out to Arizona in the Spring.
I already have spark plugs ready to go in...
Plug wires, eh?
cap and rotor, yeah, I just neglected to put that on the list.
One more thing....do you think I should be able to tackle all of this in a week? :beer:
Oh yeah, I think I might need a fan clutch, too. -thnkboutit-
This is getting very expensive, very quickly. :blink:
Edited by vengeful
How about the thermostat and timing belt tensioner. Don't forget that small little bypass coolant hose. And if you're bearings are shot you'll want to replace the races when you swap the bearings, invest in a brass punch to slowly tap the old races out of the hub.
You may not be so premature if you've had those tires on for the last 50,000 miles - the larger tire gives both lower speedo and odometer readings than actual.
I've only had the 32s for 20,000 miles....but I don't care if its at 94k or 104k, I want to get this done before I go back up to school, because I wont have an opportunity to do it or get it done within the next year. And by then it will be way overdue. Doing it early is better than doing it late, don't cha think? -thnkboutit-
:crazy:
