Entropy98 Posted May 28, 2005 Share Posted May 28, 2005 Today I noticed a noise coming from my steering wheel when I turn it going at a slow speed. It is a quiet clicking noise, sometimes it even squeaks. It feels like the clicking is coming from the lower part of the steering shaft. Has anyone ever had this happen before. I also checked my steering fluid and it is full. Anyone? Link to comment Share on other sites More sharing options...
94extreme Posted May 28, 2005 Share Posted May 28, 2005 ball joints? tie rod ends? Link to comment Share on other sites More sharing options...
headpeace Posted May 28, 2005 Share Posted May 28, 2005 sounds like your cv joints Link to comment Share on other sites More sharing options...
kmgar99 Posted May 30, 2005 Share Posted May 30, 2005 I'm with Headman.....CV-Joints....when was the last time you checked the boots? My boots have been ripped for a few months and the clicking has begun. Time for some new boots, manual hubs, and a really good greasing of the joint....if that doesn't work then its OFF with the shafts and some new ones going in. Link to comment Share on other sites More sharing options...
94extreme Posted May 31, 2005 Share Posted May 31, 2005 I'm with Headman.....CV-Joints....when was the last time you checked the boots? My boots have been ripped for a few months and the clicking has begun. Time for some new boots, manual hubs, and a really good greasing of the joint....if that doesn't work then its OFF with the shafts and some new ones going in. if you can shake them and they are loose you might as well save yourself some trouble and put in new shafts right off the bat.. no sense doing this job twice... Link to comment Share on other sites More sharing options...
Mr. Pickles Posted May 31, 2005 Share Posted May 31, 2005 (edited) I'm with Headman.....CV-Joints....when was the last time you checked the boots? My boots have been ripped for a few months and the clicking has begun. Time for some new boots, manual hubs, and a really good greasing of the joint....if that doesn't work then its OFF with the shafts and some new ones going in. if you can shake them and they are loose you might as well save yourself some trouble and put in new shafts right off the bat.. no sense doing this job twice... I'll second that, if a CV is bad to where you can grab and generate any movement by hand, its toast and time to replace. Its funny how some shops don't necessarily think so though. Bye the way, my best advice if you have any sort of steering and or front suspension noise is to find a big parking lot after hours, preferably with a friend along for the ride to help diagnose. Then go for it, perfoming high and low speed corners, back and forth steering, etc. until you've sorted it out. Edited May 31, 2005 by Mr. Pickles Link to comment Share on other sites More sharing options...
squam1 Posted June 6, 2005 Share Posted June 6, 2005 When I had my front struts changed, the strut bearings got screwed up and started clicking... really annoying tic, tic tic sound when turning... Link to comment Share on other sites More sharing options...
