New front wheel bearings
I replaced the front brakes, rotors,bearings and calipers this past week. Here’s my question. When I tightened the the spindle nuts I torqued them at 70lbs and backed them off a little to put the lock nut on with the two small screws. After torquing I spun the wheel back and forth and it spun easy. When I drove it a short trip total five miles and got back to the house I noticed my front wheels were hot as hell to touch. In the FSM it says after torquing to 70 ft lbs to turn hub in both directions and then loosing spindle nut to  0 ft lbs then torque to 13 ft lbs turn wheel hub several times then torque to 13ft lbs. then check axle end play. I wasn’t able to check axle end play and didn’t loosen hub nut after I torqued it to 70 ft lbs. would this be causing my rotors and wheels to get extremely hot being it’s torqued to around 70 ft lbs? I pretty much skipped the second step. Any help would be appreciated.
The torque spec for the bearing lock nut is 4.3-13 inch pounds--just enough preload to get the play out of it, plus what it takes to get the screws in. Sounds like you ran yours at roughly 70x their intended torque. I've never run a bearing that tight, but yeah, I'd lay money that's your problem.
I don't think I'd trust that set of wheel bearings to go again.
70 ft-lbs is just to seat the bearing fully, not the final torque spec.  Snug it up, rotate the hub, loosen the nut completely (do it twice if you're not sure it's seated).  I like to also give the hub a few love taps with a dead blow when it's snugged up.  After it's loose, "tighten" 4.3-13.0 inch pounds (same emphasis as Slartibartfast that it's about 1 foot pound max, not 13 nor 70 foot pounds).  The nut is just barely against the bearing cone, and the lock washer and screw are what prevent it from backing out.
Even with a short distance, it was probably extremely harsh on the bearings.   They're probably fine, but personally I'd be pulling everything back apart, degreasing them, and visually inspecting them before putting it all back together.  Or, just address the tightening issue and let'r ride.
