Alternative Factory Nissan Rims for 97 Pathfinder
Good evening everyone!
I am looking for a set of rims for my 97 Pathfinder SE. It has the stock 15 inch rims, however, there are not too many options for tires and I'm looking for a set from either frontiers or later model Pathfinders. I know for sure that the 17 inch rims from the 2004 Pathfinders will fit, but will 16 inch Frontier rims fit without any issues? Do these rims have the same bore size as the factory 15 inch rims I have? I do have manual locking hubs on my Pathfinder.
Are there any other options that will fit my vehicle? I have seen some 4Runner rims on these trucks too.
Here is a link to the picture of the rims I am currently looking at.
https://imgur.com/a/0rT48Tm
Thank you
Those look like a smaller lug pattern. Looks like the D40 Fronty went to 6 on 4.5" rather than 6 on 5.5". I would assume the D22 Fronty wheels would fit the lugs, but I don't know what they had as far as diameters and offsets and whatnot.
Any first gen Pathfinder, hard body, Xterra, or frontier wheels will fit. Supercharged Xterras came with 17" wheels. Probably not hard to find a set of those.
The 2nd gen Xterra/frontier like slart said have a different bolt pattern and won't fit.
Many aftermarket Chevy wheels will also fit. Be careful with Toyota wheels, you'll likely need different lug nuts for those.
Edited by adamzan
Thank you! I'll try to find a set of those. Most places I'm calling either don't have them or don't have the full set.
So essentially any of those vehicles up to 2004? Also including the supercharged Frontiers?
So i found these rims of an 03 Pathfinder SE: https://imgur.com/a/YkOPJK2
Door jam says 255/65/r16. Unfortunately, I'm getting 1 tire option when searching online.
Is it safe and okay to install 255/70/r16 tires on these rims wihtout issue for my 1997 Pathfinder SE? Vehicle is on a 1 inch spacer lift.
Thank you.
