RowOSU Posted May 19, 2005 Share Posted May 19, 2005 I am trying to decide if I should/can put the manual hubs on before the 7 hour drive back home from school. How hard is the installation? Can it be done in a parking lot with the right tools? Thanks in advance. Link to comment Share on other sites More sharing options...
herm Posted May 19, 2005 Share Posted May 19, 2005 Yes, No and Maybe - i thought it would be easy, but it wasn't. I gave up and had a real mechanic do it. Mine was pretty rusty - just beating the crap out of the dust cap to break it free was difficult, and from there it got worse. So, since it doesn't have to be done, I'd suggest you don't tackle it the day before a major roadtrip. Link to comment Share on other sites More sharing options...
Racer38 Posted May 19, 2005 Share Posted May 19, 2005 Go for it, it only took me 30 minutes per side to do. I didnt even have to use the supplied studs as my 2001 already had studs that were the right size and length. Link to comment Share on other sites More sharing options...
XPLORx4 Posted May 20, 2005 Share Posted May 20, 2005 (edited) Yeah, sorry my website is woefully out of date. Here's a link to photos of the manual hub installation: http://www.xplorx4.com/Pathfinder/upgrades/warnhubs After having the hubs installed for some time and doing maintenance on them, I recommend putting a couple fingerfuls of grease inside the warn hub body. I also highly recommend using snap-ring pliers to remove the snap-ring, instead of needlenose pliers like I show in my pics. Finally, replace your original studs if possible with cap screws. I have had to replace both wheel hubs ($200 each!) because the original drive flange studs broke off inside, and I was not able to drill them out. Here are pics of how to replace the wheel hubs, including bearing repacking. http://www.xplorx4.com/Pathfinder/upgrades/hub_replacement/ Edited May 20, 2005 by XPLORx4 Link to comment Share on other sites More sharing options...
RowOSU Posted May 20, 2005 Author Share Posted May 20, 2005 GREAT, that is just what I was looking for. I don't like paying shops for stuff like that. Thanks for the advice! Link to comment Share on other sites More sharing options...
herm Posted May 20, 2005 Share Posted May 20, 2005 dean - what were you doing when the studs broke? or did you just notice they were busted later? m. Link to comment Share on other sites More sharing options...
