dSaint Posted January 10, 2024 Share Posted January 10, 2024 Hi everyone, I watched Tyler's great video explaining why lifted R50's need appropriate backspacing and offset (thanks @PathyDude17 - great video!). I was hoping to source some ideas on what manufacturers make steel wheels in our bolt pattern and Tyler's suggested specifications. Pro Comp makes a great steel wheel in a 6 on 5.5 bolt patter with -19mm and 3.75", but it appears to only come in a 15" diameter. I was hoping to get 16" or maybe 17" to balance rubber with wheel. Does anyone have recommendations of other manufacturers with these specs that would work for larger wheels on an R50? Thanks in advance David Link to comment Share on other sites More sharing options...
XPLORx4 Posted January 15, 2024 Share Posted January 15, 2024 Do you want steel or alloy? It may be very difficult to find 16" or 17" steel wheels that look halfway decent, but you could always try googling: 16" steel wheels 17" steel wheels Link to comment Share on other sites More sharing options...
Dbot Posted February 4, 2024 Share Posted February 4, 2024 I'm running Jeg's 16x8 steelies. It has a bit more offset though. Part number 555-681034 (Less than $80 right now) JEGS 555-681034 D Window Wheel [Size: 16" x 8"] Black - JEGS Size: 16" x 8" Bolt Pattern: 6 x 5.50" Back Spacing: 4.00" Offset: -12 mm Center Bore: 4.25 I ran 265 65r16 tires on them. Without a lift, they stick out and they won't tuck in the fenders during flexing and if you bottom out, the tire rubs in the back. If you're lifted, then they tuck in the fenders when flexing. 1 Link to comment Share on other sites More sharing options...
Nolus Posted May 31 Share Posted May 31 On 2/4/2024 at 12:47 PM, Dbot said: I'm running Jeg's 16x8 steelies. It has a bit more offset though. Part number 555-681034 (Less than $80 right now) JEGS 555-681034 D Window Wheel [Size: 16" x 8"] Black - JEGS Size: 16" x 8" Bolt Pattern: 6 x 5.50" Back Spacing: 4.00" Offset: -12 mm Center Bore: 4.25 I ran 265 65r16 tires on them. Without a lift, they stick out and they won't tuck in the fenders during flexing and if you bottom out, the tire rubs in the back. If you're lifted, then they tuck in the fenders when flexing. Could you link which tires you got for those rims? I can’t find 265/65r16 anywhere Link to comment Share on other sites More sharing options...
