Wheel Recommendations for R50
dSaint
Hi everyone,
I watched Tyler's great video explaining why lifted R50's need appropriate backspacing and offset (thanks @PathyDude17  - great video!). I was hoping to source some ideas on what manufacturers make steel wheels in our bolt pattern and Tyler's suggested specifications.
Pro Comp makes a great steel wheel in a 6 on 5.5 bolt patter with -19mm  and 3.75", but it appears to only come in a 15" diameter. I was hoping to get 16" or maybe 17" to balance rubber with wheel.
Does anyone have recommendations of other manufacturers with these specs that would work for larger wheels on an R50?
Thanks in advance
David
  • 3 weeks later...
I'm running Jeg's 16x8 steelies. It has a bit more offset though.
Part number 555-681034 (Less than $80 right now) JEGS 555-681034 D Window Wheel [Size: 16" x 8"] Black - JEGS
  • Size: 16" x 8"
  • Bolt Pattern: 6 x 5.50"
  • Back Spacing: 4.00"
  • Offset: -12 mm
  • Center Bore: 4.25
I ran 265 65r16 tires on them. Without a lift, they stick out and they won't tuck in the fenders during flexing and if you bottom out, the tire rubs in the back. If you're lifted, then they tuck in the fenders when flexing. embed?resid=8A40F5A29BD0C4!76987&authkey
  • 1 year later...
  • Size: 16" x 8"
  • Offset: -12 mm
  • Center Bore: 4.25
Could you link which tires you got for those rims? I can’t find 265/65r16 anywhere
