vanuatoo Posted November 17, 2022 Share Posted November 17, 2022 I need to replace Bank 2 Sensor 1. Which o2 socket would you recommend? There are many choices on Amazon. Link to comment Share on other sites More sharing options...
hawairish Posted November 18, 2022 Share Posted November 18, 2022 12 hours ago, vanuatoo said: I need to replace Bank 2 Sensor 1. Which o2 socket would you recommend? There are many choices on Amazon. I recommend renting a kit from a local auto parts store if you have no long-term need for them. Just be sure to check how much time they allow for loaning-out. Beyond that, if really wanting to own a kit, get something with a variety since each sensor takes a little different effort to remove. B2S1 should be fairly easy to access. B1S1 is the pain. Both S2 are easy access. Link to comment Share on other sites More sharing options...
vanuatoo Posted November 18, 2022 Author Share Posted November 18, 2022 39 minutes ago, hawairish said: I recommend renting a kit from a local auto parts store if you have no long-term need for them. Just be sure to check how much time they allow for loaning-out. Beyond that, if really wanting to own a kit, get something with a variety since each sensor takes a little different effort to remove. B2S1 should be fairly easy to access. B1S1 is the pain. Both S2 are easy access. Do I understand right that B2 is the driver side? Link to comment Share on other sites More sharing options...
Strato_54 Posted November 18, 2022 Share Posted November 18, 2022 (edited) Bank 1 is usually determined by the location of cylinder 1. Sensor 1 is Pre-catalytic and sensor 2 is after. I just took an old socket and cut a notch out of the side, and filed down the edge. EDIT: NO IM WRONG. it is bank 2 on the VQ but its still determined by the 1st cylinder Edited November 18, 2022 by Strato_54 1 Link to comment Share on other sites More sharing options...
hawairish Posted November 18, 2022 Share Posted November 18, 2022 On the VQ 3.5L, passenger side is B1, driver side is B2…and I’m fairly certain the same is true for the VG 3.3L engine. It is determined by whichever side has the forward-most cylinder. Link to comment Share on other sites More sharing options...
vanuatoo Posted November 18, 2022 Author Share Posted November 18, 2022 Unfortunately I don't live in USA and there is no auto parts store from which I can borrow the tools. https://www.amazon.com/BTSHUB-Oxygen-Replace-Sensors-Universal/dp/B08G8R347J/ref=sr_1_5?crid=9ZINRG4E2NFW&keywords=oxygen+sensor+socket+1%2F2+drive&qid=1668760889&s=automotive&sprefix=oxygen+sensor+socket+1%2Cautomotive%2C305&sr=1-5 Will this kit be ok for all sensors? Link to comment Share on other sites More sharing options...
hawairish Posted November 18, 2022 Share Posted November 18, 2022 12 hours ago, vanuatoo said: Unfortunately I don't live in USA and there is no auto parts store from which I can borrow the tools. https://www.amazon.com/BTSHUB-Oxygen-Replace-Sensors-Universal/dp/B08G8R347J/ref=sr_1_5?crid=9ZINRG4E2NFW&keywords=oxygen+sensor+socket+1%2F2+drive&qid=1668760889&s=automotive&sprefix=oxygen+sensor+socket+1%2Cautomotive%2C305&sr=1-5 Will this kit be ok for all sensors? Gotcha. Sorry, was browsing from the mobile site and couldn't see your location or truck. That kit looks suitable; looks fairly identical to the set I rented a few months ago. The straight socket is great for the lowers, while the crowfoot ones more suitable for the uppers due to working space. Link to comment Share on other sites More sharing options...
2000Pathfinder Posted December 11, 2022 Share Posted December 11, 2022 I have an O2 sensor that flags the Service Engine Soon. More of a nuiance but..when I asked at the dealer in passing they said that the ECU would need to be updated since the software was not compatible to the new sensors. I have yet to do it then. However I am restoring my Pathfinder and am intersted if you have replaced your sensors yet. Link to comment Share on other sites More sharing options...
