Guest jacotaco Posted April 28, 2005 Share Posted April 28, 2005 my 93 Pathfinder has a leaking ac. I've tried several attempts at recharging with r-134a, it was cold for a little bit but then it smelt like shrimp in the car and eventually the compressors shuts off again. I've tried stop leak and even super seal stop leak and yet it's still leaking. It's smells as if it's leaking under the dash. Any Ideas? thanks Link to comment Share on other sites More sharing options...
GrimGreg Posted April 28, 2005 Share Posted April 28, 2005 Could be a leak in the evaporator, mine sprung a leak one day and I got a blast of refrigerant out of the vents. Link to comment Share on other sites More sharing options...
M in KC Posted April 29, 2005 Share Posted April 29, 2005 Next time you recharge the system put some dye in the refrig oil. This is the acid test for a fugitive freon leak(s). The stuff I used last was a chartrouse color. sly Mike Link to comment Share on other sites More sharing options...
