Removing intake manifold VG30E
Patricio
Hi, Im bringing a 91 Pathfinder back to life and currently need to remove injectors but I can’t seem to find out how to remove the intake plenum, i’ve removed all the bolts I could find but still wont come off. Any help would be greatly appreciated
You have 5 6mm Allen bolts, a couple of regular hex head bolts on the left side for the brace bracket, EGR pipe, wiring to unplug and grounds to undo. Also have 2 coolant hoses at the back and 2 more at the throttle body. Some vac lines are attached as well.
  • 1 year later...
Anyone have a video of this? gota do it soon for a knock sensor...
  • 2 years later...
