2JZT100 Posted February 22, 2019 Share Posted February 22, 2019 Hello! I'm a new member here and let me introduce myself before I ask for my plea of help. Few weeks ago, my mom asked me if I could do some repairs to her 99.5 Pathfinder, I said yes like any good son would do. I only took the job because I was very intrigued about Nissan's VG. Personally I have a lot of experience with Toyota's 5VZ and I was like "How hard can it be, THIS FINNA BE A BREEZE." (big mistake). So first thing I took care of was the fuel filter, it was kinda tricky to deal with but I got it done. So I moved to the front and got ready for the main meal, the replacement of the Knock sensor and all the gaskets in between and the valve cover gaskets of course. So it was going pretty swell until I was about to take off the last bolt of the intake manifold. And mind you, this is the one in the very back against the firewall, I go in to loosen it and after one decent turn the head strips... It's been a few days since this tragic event has occurred, i've tried everything from rubber bands to speed outs. If you guys have an ideas please help me out. Link to comment Share on other sites More sharing options...
Slartibartfast Posted February 23, 2019 Share Posted February 23, 2019 Always has to be the hard one to get to, doesn't it? The only thing I've managed to do with a normal easy-out is snap it off inside the fastener. I've seen sockets that are cut like an inverted easy-out, if that makes sense. Might give that a go if there's room for it. Given that the fastener's borked anyway, you could try slotting its head (if you can get a hacksaw back there) so you can get a straight screwdriver on it and try to work it loose that way. If you can get a drill to it, you could just drill out the head like a rivet, freeing the manifold, and then extract the stud with vise grips (or weld a nut to it if you have a welder). You could probably cut the head off with a hacksaw blade or grinding it down to nothing with a file if it came to that. Hopefully it doesn't come to that! 1 Link to comment Share on other sites More sharing options...
QuasarDecimari Posted February 23, 2019 Share Posted February 23, 2019 Like Slartibartfast said, my go-to in a sticky situation like that would be to weld a nut to it, but if that isn't an option, or you don't know too much about how, it'd be better not to get a welder in there. When I rebuilt my VQ, I was close to pulling off the heads, and I just had one last nut on the back of the engine to remove (to the infamous cooling rails that run to the heads). Of course, the final nut stripped enough that a regular wrench wouldn't get on it, and it was such an awkward area to get to that I couldn't get vice grips or anything more brutal back there. Even a welder wouldn't fit. I got lucky, though. I had a friend make a run to the auto parts store and get a set of those Grip-Tite wrenches, as the sockets had worked really well for me in the past. I decided to bet my money on it working, and thankfully they did the trick. If there's anything left of the bolt/nut head, I would definitely try out the Grip-Tite wrenches or sockets, whichever will fit, as they worked a lot better than I thought they would. Link to comment Share on other sites More sharing options...
IzaiahGarza Posted August 29, 2022 Share Posted August 29, 2022 (edited) Hey man. Yep, it’s always been so. Rivets are really strong enough to withstand overload. I have a friend who works at Scrooz. He says customers often buy their rivets (https://www.scrooz.com.au/fasteners/rivets/). Rivets are universal indeed. Btw, I’m also sick and tired of working on my car. It takes all my leisure time, man! But I still love my Nissan so much. I’d never buy a plane instead of it. I’d just buy a nice car. Just joking. I’ve given off my heart and soul to this car. Btw, guys, how much time does working on your car take you weekly? Edited August 29, 2022 by IzaiahGarza Link to comment Share on other sites More sharing options...
