SAS r50 :)
johann_peralta
35 minutes ago, mjotrainbrain said:
I can click those links and see the pics, but in neither thread can I see your most recent embedded photos (and scrolling up I notice I can't see all of your previous photos anymore, although a good number of them I can).  Personally I use Imgur (because it's been around long enough that I trust it to continue to stick around), people use other sites with great success (I believe Flickr is another one; just don't use PhotoBucket!).
That rig looks like a beast in the pics with the big tires bolted on!  Any driveshaft binding when rolling it around?
dang.. it's weird because I can see them all.
I haven't built the driveshaft yet, but I'm confident it won't bind. The front will more than likely get a CV joint by the axle and a cardan joint at the tcase.
On 6/21/2019 at 9:19 AM, XPLORx4 said:
Why did you have to weld two pieces in?
I originally added one piece in and then realized I forgot to keep the u joints in phase, so it was cut and put back together in phase.
  • 3 weeks later...
On 6/26/2019 at 8:14 PM, jlduthie said:
This is fantastic. Out of my scope but amazing work!
Thank you. I'm no pro or have I ever done something like this before. It's a learning experience for sure.
  • 1 month later...
I have no idea. I'm just doing one thing at a time for now. I need to get back under it and finish welding all the spots I couldn't reach before while it was in the shed, and finish the small things first
  • 5 months later...
Bringing this back to light because i'm gonna redo the suspension on this car. Going to drop it down to around 4-6" lift and 31s-35s. Learned a lot from the last build and now want to make this thing better.
