Leveling kit HELP!
Ole_Rosie_R50
depends what you want? you can level it out, add whatever height you want front and back. Bolts come with it if you order sfcreation. I also would be careful ordering big spacers. front spacers at or above 2" (2.5" lift) may cause problems with your CV's
Edited by PathyDude17
Exact... When you order spacers, you will get the right size of bolts with it. On the other hand, if you are upgrading an existing installation and would like a different size of bolts, then you can specify it when you order. For example, you already have 1" spacers installed. You want to go higher and order another 1" spacers. If you do not specify anything, you will get 2.5" bolts. This will be too short if you plan on stacking the spacers with the ones you already have installed. This is why this option is there...so you can specify 3.5" long bolts with your 1" spacer kit.
Cheers.
  • Thanks 1
