Wheel bearing replacement
1badqx4
Hello every one I got a new set of front wheel bearings races and seals. about how long and how difficult is this job to complete? are there special tools I need?
I'll try and post the manual in a few. It's pretty simple, as long as you know all the little pieces you're getting into. I attempted to upload the pages on my phone but it didn't work. Just a minute...
Edited by CortlandCH
Its pretty straight forward. Few crucial things to remember-
The wheel bearings need to be spotless. No dust, dirt, debris.. etc. Keep them packaged until you are ready to grease them up and install them
Pack the bearings with grease really well. If by hand, roll the bearing, in your recently clean or gloved hand, with a dab of grease in your palm. You want to fill the entire bearing.
When setting end play on the axle shaft ( without a dial indicator) hand tighten pre-load nut until the rotor wont spin freely or the nut stops and then turn back ( loosen) the nut 1/8 to 1/4 turn. Pull on the rotor/hub assembly and feel for a very small amount of play. spin the rotor, look for free, unbound rotation. If it seems to bind at all or come to a sudden stop adjust the pre-load nut.
Avoid damage to the inner bearing race seating surface on the hub. If you nick or score this surface when removing the old bearings/races it must be dressed before installing a new set. Again, this must also be free of dust, dirt, debris.
You can use the old races to drive in new units to a point. Avoid going to far as the old races will start to seat in the hub, making it difficult to remove.
Take your time, take pictures as you go so you can reference the images for reassembly and keep it as clean as possible. Good luck.
Front%20and%20Rear%20Axle-17_zpsmh69zcop
Front%20and%20Rear%20Axle-7_zpsmdpkt90g.
Front%20and%20Rear%20Axle-8_zpsmrkwp5zd.
Front%20and%20Rear%20Axle-9_zpsdnkcmixu.
Front%20and%20Rear%20Axle-10_zpsd7trbkmm
Front%20and%20Rear%20Axle-11_zps3yciqal0
Front%20and%20Rear%20Axle-16_zpsdjdkmlkt
Edited by TowndawgR50
No worries, CortlandCH. Didnt mean to beat you to it. Figured you had problems loading images or something and I know how little time folks have to get stuff done, myself included.
Ws Guardians 2 ok? On the fence about going to see it in theaters or waiting for it to become available on demand and watching at home.
Haha I'm not hurt. I originally got all the images in on my phone, but then (probably should have known it would happen) TinyPic just displayed that the images were deleted. Go figure!
The movie was amazing. Though some would argue, I would say it was just as good, if not better than the first. I'd see it if you liked the first one.
  • 1 year later...
Just did this service along with every other front suspension component.  I replaced the outer and inner bearing's and races.  used a punch to knock out the old races.  I did score the race seating surface but filed down the high spots i created.  Car runs great.  One tip would be to re-tighten the spool nut after a few miles.
Edited by trusovici
  • 5 years later...
Hiya! I am preparing to do a lot of cursing and swearing, but first, I am trying to get all I need to ta kle my noises passenger front wheel....
The spindle socket. Is the two prong important? It seems a challenge to purchase. I saw one for $19 on Amazon,  SUNEX TOOLS 10202 4 Wheel Drive Spindle Nut Wrench https://a.co/d/0ast2kWS but it broke for some users. What do you recommend?
I am probably going to follow this guy for install:
I will be replacing my rotors, they got markings on them, so I'll finally replace my brakes, although I've had no issues since I bought this baby 7years ago....but the hub in the video -I have 4x4. I hope it will work itself out once I start taking things apart.
The two prong docket is my biggest concern. Where do I find a durable one? I notice guy put somr sort of plate or washer on the socket when he is putting things backmtogether. What is that "plate"?  Hub Socket Nut Kit 1/2" Drive 54mm&Front Adjusting Hub Nut Kit Fit for Landcruiser, Hilux 4x4, Nissan Patrol https://a.co/d/03CygeOf this one has lots of disk / plates. Am I over thinking things?
Thank you in advance!!!!!!
Edited by PamPoovey
I used a similar socket to the top one you linked. It's a bit fiddly to keep engaged (only grabs in two places), and IIRC I had to do a little grinding to make the pegs fit right. But unless it's made of Jolly Ranchers, you're overtorquing the bejeezus out of the bearing, or you try to take it apart without taking the screws out first, I think you'd have to try pretty hard to break it.
The plate you're seeing might be the lock nut, which is the component that the socket turns, or the lock washer, which goes over the nut and has holes for the screws that lock it in place. I don't think the second tool you linked would fit anything on an R50.
Thank you so very much for getting back to me! I was hoping it was the locking nut ring! I should have all the parts and special tools in for the following weekend to tackle.  4th of July weekend would be nicer but argh
