Ignition coils
Sliderslider
True for the 3.3L, but he's got the 3.5L, which uses individual coil packs.
Sliderslider, are two with M ohms a different brand by chance? Not sure if it makes a difference, and in the FSM, I only see that a 0-ohm reading is no-good; everything else is ok.
Did you write down the readings? Not sure of the specs but I would be suspicious of a reading that far out. A reading of zero would mean a dead short, and resistance that high sounds like it's just about an open circuit, and that's not good either.
