whittoncrew Posted February 29, 2016 Share Posted February 29, 2016 I currently have a 1995 pathy with a automatic. I have a opportunity to convert to a manual, but the donor vehicle is a 1987 hardbody 4x4. my question is does the 87 and 95 have the same bolt pattern? any other info would be greatly appreciated Link to comment Share on other sites More sharing options...
silverton Posted March 2, 2016 Share Posted March 2, 2016 If the engines are the same, yes. Link to comment Share on other sites More sharing options...
Dma251 Posted March 5, 2016 Share Posted March 5, 2016 I've done it and it's not hard at all. Especially if you have a complete doner parts rig. The hardest part For me was getting the pedal assembly installed without removing the whole dashboard. Link to comment Share on other sites More sharing options...
Harbinger Posted March 12, 2016 Share Posted March 12, 2016 The hardest part For me was getting the pedal assembly installed without removing the whole dashboard. Truth. I haven't seen it done without removing the steering column. Link to comment Share on other sites More sharing options...
WD21colorado Posted March 19, 2016 Share Posted March 19, 2016 i have recently did an auto to manual swap. the whole swap took me about 4 days. ( would of taken 3 days if the bolts on the flex plate to torque converter werent stripped). the bell housing for the vg30 are the same but the studs are longer on the manual than they are for the auto also the transmission cross member sits differently than the auto also most likely your newer manual from the pre 1990's pathfinders have a shorter fifth gear something like 0.86:1 vs 0.73:1 on the auto. one more thing both tx-10 transfer-case are compatible but the transfer case slide rail on the outside of the transfer case appears to be a different length on the pre 90's models. if any other question just post it and other people should answer. Link to comment Share on other sites More sharing options...
cnd.vlad Posted March 25, 2021 Share Posted March 25, 2021 Does anyone have a guide for the swap though? 1 Link to comment Share on other sites More sharing options...
Keeyinn89pathfinder Posted April 23, 2021 Share Posted April 23, 2021 On 3/24/2021 at 5:22 PM, cnd.vlad said: Does anyone have a guide for the swap though? I can start one and take pictures I'll even do a youtube if you want because im doing a vg33ett with an 03 exterra 5 speed in my 1991! Link to comment Share on other sites More sharing options...
GkLapp Posted April 27, 2021 Share Posted April 27, 2021 A video for the swap will be great. I am curious as to what will happen to the electronics related to the automatic. Link to comment Share on other sites More sharing options...
