2001 Rear drum brakes rusted
Guest girlpath
Guest girlpath
:help: The drum housings on my rear brakes are really rusted. I bought this 2001 Pathy used last December 2004 with just under 12k miles. Apparently, it sat around quite a bit.
Anyway, the drums look nasty, and I'd like to clean them up or otherwise brighten them. I have NO IDEA about brakes and would like some feedback.
Thanks!
Hopefully you've released the parking brake. If your brake drums are not severely worn/grooved, you should be able to slide the brake drum right off the lugnut studs. If not, there are a couple of holes in the brake drum into which you can insert a bolt (metric size, sorry I don't know the size or pitch of the threads) and as you tighten the bolt, it will push the drum away from the wheel hub.
It is not a bolt that you need to loose. On the back top of the brake housing, there is long slot. Insert a screwdriver and turn the star wheel in the housing to loosen the break shoes. If you just want to clean it and paint it, don't bother taking off the drum. just cover everything with masking tape to clean and paint.
