Turn signal relocation
Megaton
I know some of you guys with winch bumpers have relocated your turn indicators to the marker light. Could you tell me how it's done? The lenses on mine are cracking and getting water and debris in them. I plan on a winch bumper in the future so I need to do it anyway. Thanks for the help.
Its not that the socket is the same, its that the harnesses male plug fits into the female plug on the side marker, the sockets themselves are very different, as well as the bulb size. The side markers are not very bright, i went 4 years before i finally noticed that one was out. :fail:
-Kyle
01Pathmaker,I thought of the same thing but there isn't enough clearance inside the housing of a 97 for a 1157 bulb. The LED arrays are shorter but I will have to check for clearance. The twist in bulb holders are much larger for the turn signal than for the marker so that hole would have to be enlarged. Thanks everyone for the input.
