putting in new speakers on a 00 pathfinder
fearkobe
Hi I'm replacing all the speakers on a 00 pathfinder cause the stock ones are turn and shot. They are clarions. Anyway ordered some pioneers of eBay. My question is I don't want to cut the stock plug off the speaker harness and I was wondering if any stereo shops carry or can get the plug that plugs into the stock speaker wire? Also how can I tell which wire is positive or negative? Thanks
What I did was cut the plug off the old speakers I was removing. Then I spliced that on to the wires on the new speakers. After soldering and shrink wrapping, it was a plug n play deal using the factory connector.
Hi
I'm new to here. I usually do as jyeager mentioned. cut then solder and shrink tube them. If you decide to cut the harness then leave about 1.5" of wire on the harness just in case you ever wanna put it back ( I wouldnt but you might). Here are common Nissan colors.
Speaker(s)
RF(+):BROWN
RF(-):BRN/WHI
LF(+):BLU/WHI
LF(-):BLU/YEL
RR(+):BLUE
RR(-):PINK
LR(+):RED
LR(-):GREEN
