fearkobe Posted June 29, 2015 Share Posted June 29, 2015 Hi I'm replacing all the speakers on a 00 pathfinder cause the stock ones are turn and shot. They are clarions. Anyway ordered some pioneers of eBay. My question is I don't want to cut the stock plug off the speaker harness and I was wondering if any stereo shops carry or can get the plug that plugs into the stock speaker wire? Also how can I tell which wire is positive or negative? Thanks Link to comment Share on other sites More sharing options...
jyeager Posted June 29, 2015 Share Posted June 29, 2015 Hi I'm replacing all the speakers on a 00 pathfinder cause the stock ones are turn and shot. They are clarions. Anyway ordered some pioneers of eBay. My question is I don't want to cut the stock plug off the speaker harness and I was wondering if any stereo shops carry or can get the plug that plugs into the stock speaker wire? Also how can I tell which wire is positive or negative? Thanks What I did was cut the plug off the old speakers I was removing. Then I spliced that on to the wires on the new speakers. After soldering and shrink wrapping, it was a plug n play deal using the factory connector. Link to comment Share on other sites More sharing options...
XPLORx4 Posted June 29, 2015 Share Posted June 29, 2015 Metra makes speaker adapters so you don't have to cut wires. http://www.bestbuy.com/site/metra-speaker-wire-harness-adapter-for-most-nissan-vehicles-multicolor/2206838.p?id=1051826167595&skuId=2206838 Link to comment Share on other sites More sharing options...
theworks001 Posted June 30, 2015 Share Posted June 30, 2015 Hi I'm new to here. I usually do as jyeager mentioned. cut then solder and shrink tube them. If you decide to cut the harness then leave about 1.5" of wire on the harness just in case you ever wanna put it back ( I wouldnt but you might). Here are common Nissan colors. Speaker(s) RF(+):BROWN RF(-):BRN/WHI LF(+):BLU/WHI LF(-):BLU/YEL RR(+):BLUE RR(-):PINK LR(+):RED LR(-):GREEN Link to comment Share on other sites More sharing options...
