SpecialWarr Posted February 17, 2015 Share Posted February 17, 2015 So I think I'm back to five operating cylinders again. I had a moment after getting off of the highway just before pulling into the parking lot when things went strange. The idle was bouncing around from 1500 to 1800 and back a dozen times while on the brakes up to the corner. No drop in RPMs when I pulled into the parking lot but the motor sounded good. Then I went out to get lunch a few hours later and the idle sounded like crap and I could hear backfiring like mad.... it didn't sound like one consistent cylinder though. ( I assume that you can hear one cylinder by itself.... sounds like drum beat yes?? So a lack of one would sound like one missing somewhere, right? or am I crazy? jumping to conclusions? May I mine the collective for some more info on how to identify a single cylinder misfire, because the YouTube videos have no sound quality that can let me hear anything other than a motor running. Thanks people! Link to comment Share on other sites More sharing options...
adamzan Posted February 17, 2015 Share Posted February 17, 2015 With it idling pull off one plug wire at a time (and then put it back) and see which one makes no difference. Link to comment Share on other sites More sharing options...
Precise1 Posted February 17, 2015 Share Posted February 17, 2015 Hook up a timing light (or anything that fires/triggers from induction) and test all wires first, then pull them one by one. Check your cap and rotor as well, someone's rotor screw fell out recently, which caused RTA (random timing adjustment), and once when mine was stumbling at lower RPM, I noticed my dizzy cap had no center electrode to the rotor, it was just running by arcing... B Link to comment Share on other sites More sharing options...
SpecialWarr Posted February 17, 2015 Author Share Posted February 17, 2015 Cool, thanks gentlemen! I'll take a run at that this week when I get a chance to bring the truck inside to work on it and let everyone know what the problem was. Link to comment Share on other sites More sharing options...
