steki87 Posted October 30, 2014 Share Posted October 30, 2014 it wont start. it won't click over and doesn't make any noise. I need help! My headlights turn on but that's it. Link to comment Share on other sites More sharing options...
Terranovation Posted October 30, 2014 Share Posted October 30, 2014 Fusible link is dead, needs to be replaced. Same thing happened with mine. Everything was dead except headlights. Also check battery connections and alternator. Can also be a short in the ignition relay. Link to comment Share on other sites More sharing options...
Precise1 Posted October 30, 2014 Share Posted October 30, 2014 Are the headlights as bright as normal? What voltage at the battery with no lights/ignition on? It could be at the ignition switch, the starter relay on the passenger fender, connections, etc. Check the battery voltage, the physical connections, the ground where it ties into the body/frame, remove the relay/check contacts/tap it and reinstall. Do one thing at a time, trying to start it in between. That way if something changes, you know what affected it. Do you have a multimeter or 12v test light? B Link to comment Share on other sites More sharing options...
Terranovation Posted October 30, 2014 Share Posted October 30, 2014 Another thing to add is your fusible link is near the positive terminal on your battery there should be a couple of white color wires there. Look for something that is fried. I had an electrician look at mine and he pulled on a wire and it snapped like a piece of lead. That's the sign of a fried wire, the filaments in the wire cook and bond together like a piece of melted lead. Fusible link wire can be bought at any electronics store or hardware store. Link to comment Share on other sites More sharing options...
Slartibartfast Posted October 30, 2014 Share Posted October 30, 2014 I would start with the battery connections. If they're corroded/loose, pop them off, clean the posts and clamps, put them back together with some dielectric grease (or whatever grease is handy) and see if that doesn't do the trick. I've seen a car where everything seemed to work but the lights went out if you tried to start it (and no sound from the starter), and the positive terminal was so loose it wiggled and sparked when I messed with it. Started right up with the clamp re-tightened. Link to comment Share on other sites More sharing options...
SpecialWarr Posted November 23, 2014 Share Posted November 23, 2014 You may want to try the METER fuse in the fuse box. I found that it has to be intact to get anything to happen in my wd21! Link to comment Share on other sites More sharing options...
