delavoie Posted February 7, 2005 Share Posted February 7, 2005 Yesterday i was out in the mountains for a sunday cruise... well on my way back i hit some pretty big dips/bumps. After hitting one of them, all of a sudden my cd player turned off. So i stop the truck and check the fuses, they are all ok. I pulled the cd deck out and checked it's fuse, it's still good also. Now everytime i start the truck, the dash clock is always reset to 1:00, and the deck is still not working. I checked the fuses again today, because my dome lights are no longer working either, i noticed that the fuse for the interior lights is now blown. I checked all the wires on the deck, they all look good, and the cd player seems to be getting some power, because the anti-theft light blinks when i remove the face plate. Anyone have any ideas what could be causing these electrical problems??? Link to comment Share on other sites More sharing options...
90seven Posted February 7, 2005 Share Posted February 7, 2005 I need to take a look at my mom's accord. They stereo just died one day. Fuses are ok but I think its inside the dash that somethings burnt, fried. How hard is it to open the dash? Thinking of probably taking it to the dealer. Link to comment Share on other sites More sharing options...
jj big shoe Posted February 7, 2005 Share Posted February 7, 2005 The same thing happened on my '87 but I can't for the life of me remember what it was now. Double check all the fuses under the dash and also take a look at the cigatette lighter circuit. I'll post again if I can remember what it was on mine, darn alcohol. Link to comment Share on other sites More sharing options...
delavoie Posted February 8, 2005 Author Share Posted February 8, 2005 I also noticed that when i open my door that the dash clock will go out, when the door is closed it's on again, but resets to 1:00. My dash light for the "door open" blinks on and off constantly when the truck is on, but it's not fully bright just dim. But if i switch the dome light on and off, the "door open" light will come on solid. But there is no door open!! Some very weird electrical problems here,, hopefully someone will be able to point me into the right direction. Thanks Link to comment Share on other sites More sharing options...
jj big shoe Posted February 8, 2005 Share Posted February 8, 2005 Man, the more you describe the problem, the more it sounds like the same one I had. I'd open the door and the clock would go out too. I still can't remember what the fix was, but I have a wierd feeling it might be the cigarette lighter circuit. Pull the bezel off and look for pinched wires or something. Maybe even disconnect it while you're troubleshooting. It's killing me that I can't remember what it was. Sorry I can't help more. I think I'm getting a touch of the Alzheimer's. Link to comment Share on other sites More sharing options...
GrimGreg Posted February 8, 2005 Share Posted February 8, 2005 Probably a bad door pin or wiring for the pin is shorting out. Link to comment Share on other sites More sharing options...
jj big shoe Posted February 8, 2005 Share Posted February 8, 2005 Probably a bad door pin or wiring for the pin is shorting out. Maybe, but that wasn't the case with mine. Whatever it was I didn't have to replace anything. I just wish my brain worked better so I could help the guy out. Link to comment Share on other sites More sharing options...
denisb Posted February 8, 2005 Share Posted February 8, 2005 Sounds like something shorting out in the door switch. Try disconnecting it and see if it goes away. Link to comment Share on other sites More sharing options...
