PeteyPathy
Interlock switch
Can anyone tell me what the switch marked "INTERLOCK" on dash to the right of steering column, and below emergency flashers is supposed to do?
When I push it the fuel light and brake light come on. Don't notice any other affect. Anyone have the original owner manual for an 87?
It bypasses the clutch safety, allowing you to start the truck by holding the switch in instead of the clutch pedal.
^ there's your answer in the nicest plainest way possible without people screaming 'search' :lol:
just don't try it with the tranny in gear :rofl: :rofl:
He will, eventually. My D720 had no such ignition override and no matter how careful I was, I lurched it with the starter several times a year. Never hit anything, but still...
A great way to move a non-running vehicle a short distance though. :D
I chased every thread I could find that mentions owner manuals, only newer manuals are online appears, FSM wiring diagram doesn't tell purpose just where wires connect.
No I won't bump start it unless i have to because of hyd clutch failure. Not only am I mechanic (the kind who turns wrenches for a living) I'm also CDL driver so accustomed to vehicles that don't have clutch interlock. I've owned several vehicles that clutch switch failed in so i just jumped it instead of replacing.
@Rebel thank you for the info.
Bypassing instead of replacing? You must be ASE certified! :rofl: (calm down it's just a joke, as was my previous comment, though there are a few threads that a search of the word "interlock " will bring up and have given you the needed info as well :aok: )
I'd add that I think it's odd that the brake and fuel light comes on when you trip the switch. Never seen that before, maybe it's just my truck.
Yes, bypassing cause I'm accustomed to not having one. What's really bad is driving tired, shifting out then looking for 6th.. Not good to hit reverse at 70 lol
There is no telling... PO screwed all kinds of stuff up on this thing. I'm fixing stuff as I find it.
That and the invisible clutch when you're in an automatic...
Back in the 80s they were having failure problems with the interlock relay, sometimes you could tap on it with a screwdriver
or something and it would work, other times we made a temp jumper wire with 10 gauge and 2 male spade connectors I have 1 in the wife's 94 pathy.
It seemed like we were having more problems with the Sentras then any other model
