captandy Posted March 20, 2014 Share Posted March 20, 2014 (edited) Blacked out my grill and factory fogs to match my recent HID headlite conversion.. They are amazingly bright, i wired directly to my factory harness Edited March 20, 2014 by captandy Link to comment Share on other sites More sharing options...
thorpe991 Posted March 20, 2014 Share Posted March 20, 2014 looks good Link to comment Share on other sites More sharing options...
Karmann Posted March 20, 2014 Share Posted March 20, 2014 Looks nice, what'd you paint your bumper with? Link to comment Share on other sites More sharing options...
dustinp Posted March 20, 2014 Share Posted March 20, 2014 Makes it look mean!especially with the bumper Link to comment Share on other sites More sharing options...
captandy Posted March 20, 2014 Author Share Posted March 20, 2014 Thanks..black auto paint and clearcoat. Sent from my HUAWEI-M931 using Tapatalk Link to comment Share on other sites More sharing options...
devonianwalk Posted March 21, 2014 Share Posted March 21, 2014 Dang. I don't know which of your R50's I like better? You, sir, have good taste! Link to comment Share on other sites More sharing options...
sroeser01 Posted March 21, 2014 Share Posted March 21, 2014 I have two of the same exact light only round on the grill and the light bar on the roof. There incredibly bright and durable for sure. Had mine under water and in deep snow no problem. Enjoy! Link to comment Share on other sites More sharing options...
thorpe991 Posted March 21, 2014 Share Posted March 21, 2014 can you put up a pick from the side because they look like you cut the grill and mounted them inline with the grill Link to comment Share on other sites More sharing options...
captandy Posted March 21, 2014 Author Share Posted March 21, 2014 (edited) Actually ,,,this was VERY simple.. i removed grill..(and didnt break it in my normal fashion..) and used existing bumper cover holes and some small stainless bolts.. Ready for this???? The holes matched up perfect for installing tuff lite brackets ! HOWEVER..as you see in picture, i installed them before i put grill back and the grill was hitting so i took them off and put grill on First and just slipped the bracket under it and was still able to reach behind and put bolts on.. NO cutting of grill Edited March 21, 2014 by captandy Link to comment Share on other sites More sharing options...
thorpe991 Posted March 21, 2014 Share Posted March 21, 2014 that looks really good almost looks factory Link to comment Share on other sites More sharing options...
tooslowforgr Posted April 1, 2014 Share Posted April 1, 2014 Andy, I would like to do the same in regards to painting the grill, Please tell me how to remove it, i tried today without success... Link to comment Share on other sites More sharing options...
ferrariowner123 Posted April 1, 2014 Share Posted April 1, 2014 Andy, I would like to do the same in regards to painting the grill, Please tell me how to remove it, i tried today without success... Get yourself a flat head screwdriver and a flashlights. The clips are located here. The four corners are easy to get to, but the middle one under the logo is a little tricky. Its best to go under the "Nissan" part of the emblem (be very careful not to scratch anything during all of this), get an idea of where the head of the clip is and then "using the force", try and line up your flat head into the clips. The clips look like this. (these clips are the same through all of the R50's) Put your flat head into the slit of the clip and twist, aligning the square head of the clip into the square hole of the grille, (its best to have some light pressure pulling on the grille away from the core support, so get a buddy or Chuck Norris this all by yourself.) Dont be afraid to break these clips. Once you have all five clips freed of the grille, it should pop right off. Now these clips are going to remain on the core support of the car and need to be removed in order to be installed back into the grille. Simply push on the two tabs at the point of the clip (what my fingers are touching in the photo). Push them together and pull. Re-installing them into the grille is sort of annoying. Next to where these clips go on the grille, there will be a small, square peg that comes out, one of the sides of the square peg will be cut at an angle, align the point of the clip (with the square end of the clip facing towards the square hole of the grille) with the angular side of the peg, push down on the clip and twist. It takes some finagling but that's how I put this in. Once all five are re-installed, do whatever you were going to do to it, line up the grille to the car (again be careful not to scratch anything) using the headlights and bumper fascia as a point of reference and push, you should hear all of the clips click back into position. Check this by pulling gently on each corner and center of the grill, or by visually checking each clip point. Hopefully that made sense. Wrote this half asleep. -Kyle Link to comment Share on other sites More sharing options...
Darek Posted April 8, 2014 Share Posted April 8, 2014 Is your rear bumper black as well? Can you post a photo? Link to comment Share on other sites More sharing options...
captandy Posted April 8, 2014 Author Share Posted April 8, 2014 (edited) painted the rear and the sides same way...as well as " fender flares"the rear bumper(no pics) the same as frony Edited April 8, 2014 by captandy Link to comment Share on other sites More sharing options...
linkinpark Posted April 8, 2014 Share Posted April 8, 2014 Have a set of those as side lights. Love them. Looks great! Link to comment Share on other sites More sharing options...
