ahardb0dy Posted March 16, 2014 Share Posted March 16, 2014 What would cause the brake pads to wear more on one side compared to the other? When I put new pads in and squeezed the pistons back in the calipers all the pistons moved freely so I doubt any of the calipers are/were bad or seized. Truck is a 2005 Chevy Tahoe, 2wd. The pads were the same both sides front and rear. Thanks Link to comment Share on other sites More sharing options...
adamzan Posted March 16, 2014 Share Posted March 16, 2014 Sticking sliders. Link to comment Share on other sites More sharing options...
ahardb0dy Posted March 17, 2014 Author Share Posted March 17, 2014 Possibly, The front calipers use the female torx heads, pain in the ass !! My T55 torx bit was kind of messed up on the tip, I got the drivers side bolt out but the pass. side was very tight, the bit kept slipping so I ended up cutting about a 1/16" off the end to get to good metal, still couldn't get the bolt out using my 1/2" ratchet so I broke out the impact gun and it came right out. Noticed on the auto parts website they have replacement caliper bolts with hex heads so I bought a pack of two of them, only need two as you swing the calipers up like with the Nissan to replace the pads. I greased the new slide pins, and the old ones in the rear, Will see how these pads wear compared to the one's I removed, next time she needs brakes. Link to comment Share on other sites More sharing options...
RF600 Posted March 17, 2014 Share Posted March 17, 2014 Single piston calipers often wear one side more than the other. They will also wear at an angle. The piston doesn't push straight out. Link to comment Share on other sites More sharing options...
ahardb0dy Posted March 17, 2014 Author Share Posted March 17, 2014 they are dual piston calipers Link to comment Share on other sites More sharing options...
thorpe991 Posted March 17, 2014 Share Posted March 17, 2014 could just been a soft pad my gf went an had good year replace the brakes on her 07 caliber and within 6 months the passenger side was about shot took it back they said it was a soft pad and replaced it free of charge. but yewar it was just a fluek thing Link to comment Share on other sites More sharing options...
ahardb0dy Posted March 17, 2014 Author Share Posted March 17, 2014 Don't know what type of pads were in the truck, they bought it used. I installed the "OE" ceramic pads front and rear from Oreily auto parts Link to comment Share on other sites More sharing options...
djratlif Posted March 17, 2014 Share Posted March 17, 2014 I would check the sliders as mentioned before, the pins get stuck and the caliper can only push on one side of the rotor. Link to comment Share on other sites More sharing options...
ahardb0dy Posted March 17, 2014 Author Share Posted March 17, 2014 They should be good now, I replaced the two lower slide pin/bolts on the front calipers and greased them and everywhere the pads sit against, in the rear I greased all the slide pins and the pad contact areas, will see next time she needs brakes I guess. I thought the caliper (s) might have been frozen but the pistons all pushed back in easily when I pushed them back in to fit the new pads using my "C" clamp Link to comment Share on other sites More sharing options...
