1993 Pathfinder 24mm tie-rod end lock bolt.
MrEviLDeD
You will need two wrenches at 24mm for the large style adjuster OR a 24mm and a 22mm for the round small style adjuster. A pipe wrench is alright for the adjuster itself (center section) if you don't mind making it ugly, but for the nut I would at least use a large crescent wrench..if you strip that nut with a pipe wrench then have fun getting it apart..
Something didn't feel right about using the pipe wrench so scrounged just enough to pick up a 24mm and a 27mm (lower ball joint crown nut) I think the center adjuster is 23mm and they didn't have one, so I am hoping the slightly loose 15/16" will suffice.
Thanks again Negarious.
Replacing inner, outer and adjuster on both sides. Just got finished passenger side.. I am out on the windings of the tie-rod ends as it pulls to the right pretty good now. I was unable to get the bolts apart. I made the mistake of trying to loosen them after I removed it instead of trying to loosen them while still on the vehicle. I will remember that for the drivers side.
