AtvStalker Posted February 14, 2014 Share Posted February 14, 2014 Okay so I DID look for this answer already...but to NO avail.. Here is the situation: Alignment done, vehicle drives straight and true, however if I turn left there is a spot in the turning of the steering wheel that there is little response and after I make my turn, what ever direction I turned the steering stays to that side when going straight. example at a stop sign the steering wheel and wheels or straight and aligned. I make a left turn, when I straighten back out the wheel will point straight but the steering wheel is turned slightly to the left. Same scenario if I turn right (wheels straightened and steering wheels points right) I am competent enough to have checked tie rods, and other related steering components. there are none that are bent or loose or worn out (ie bushings or bearings).. Since I am new to the pathy I don't know if it could be the steering column, shaft or R&P. Any suggestions? Link to comment Share on other sites More sharing options...
silverton Posted February 14, 2014 Share Posted February 14, 2014 Car50... if with a car like steering system... steering rack mount bushings? I know my SE-V6 200sx, oil from the filter would drip on the rack bushing which then causes it to wear out faster. the VG33 doesn't have that problem though as the filters in a different place. Something to look at though. 1 Link to comment Share on other sites More sharing options...
Rebelord Posted February 14, 2014 Share Posted February 14, 2014 Rack bushing. $13 each at the dealer. Quick to replace. Sent from my Moto X Link to comment Share on other sites More sharing options...
AtvStalker Posted February 14, 2014 Author Share Posted February 14, 2014 thanks for the speedy suggestions... I am looking into the bushing now... will of course keep everyone posted Link to comment Share on other sites More sharing options...
AtvStalker Posted February 14, 2014 Author Share Posted February 14, 2014 any company brand of performance bushings I should stay away from... Link to comment Share on other sites More sharing options...
Rebelord Posted February 15, 2014 Share Posted February 15, 2014 Just stay with OEM. At $13 each at the dealer. Cant go wrong. Link to comment Share on other sites More sharing options...
silverton Posted February 15, 2014 Share Posted February 15, 2014 If you can find solid or polyurethane bushings... that's what I would do. But $13 a pop from the dealer for rubber, that's pretty good. If poly is available though... Link to comment Share on other sites More sharing options...
Alkorahil Posted February 15, 2014 Share Posted February 15, 2014 (edited) As others have alrady stated, that is the first place to start to rule it out as a problem. It is inexpenise to replace them and with the vehicle being 18 years old, probably needs them anyways at that age! After you repalce them, you might need to realign it again. Edited February 15, 2014 by Alkorahil 1 Link to comment Share on other sites More sharing options...
AtvStalker Posted February 17, 2014 Author Share Posted February 17, 2014 thank all it was the one bushing that sits under the oil filter.... Link to comment Share on other sites More sharing options...
