Guest Danny Posted January 21, 2005 Share Posted January 21, 2005 Going to fire up the truck sometimes i can't turn the key over. I have to work at before it finally decides to turn. It doesn't happen every time maybe 1 out of 3. What kind of problem am i looking at. Expensive to fix?? My truck is a 1992 Pathfinder. Any help would be great. Thanks Dan Link to comment Share on other sites More sharing options...
GrimGreg Posted January 21, 2005 Share Posted January 21, 2005 Manual or automatic? Link to comment Share on other sites More sharing options...
jj big shoe Posted January 21, 2005 Share Posted January 21, 2005 Do you mean the key won't move in the ignition? The key or ignition lock tumblers are probably worn down. Try getting a new key made. If that doesn't help replace the ignition cylinder. Neither cost too much and are fairly simple to do. Link to comment Share on other sites More sharing options...
GrimGreg Posted January 22, 2005 Share Posted January 22, 2005 Do you mean the key won't move in the ignition? The key or ignition lock tumblers are probably worn down. Try getting a new key made. If that doesn't help replace the ignition cylinder. Neither cost too much and are fairly simple to do. Oh, if that's what he means then the key and cylinder might both be warn out. Mine acts funny sometimes also, but if I pull the key out and flip it over it usually works fine... Link to comment Share on other sites More sharing options...
Precise1 Posted January 23, 2005 Share Posted January 23, 2005 Definitely sounds like a key/tumbler problem. Look at the key down a light, viewing the reflection. Is it slightly bent ??? try to straighten it... I have keys to a bike where one set is a little bent and doesnt like to work where the other is fine. Imagine a key shaft with grooves that is bent, then try to turn it 90 degrees... The pattern is the same, but with a different end point, either higher or lower; tumblers dont like that. Straighten the key first, and if that doesn't work, then it is probably a wear issue and needs to be replaced. Bernard Link to comment Share on other sites More sharing options...
88pathoffroad Posted January 23, 2005 Share Posted January 23, 2005 Lube that sucker up with some lock lube or silicone oil. I bet it starts working again just fine. Link to comment Share on other sites More sharing options...
Guest Danny Posted January 29, 2005 Share Posted January 29, 2005 Thanks for the input. Problem solved, nicked Key Link to comment Share on other sites More sharing options...
