rwd5021 Posted July 21, 2013 Share Posted July 21, 2013 My 92 has a strange problem. Everytime I go through a decent amount of water/mud something gets splashed and it won't run correctly until it dries out. It seems like it's getting too much gas during this time. If I'm extremely light on the gas pedal it will run normal, but if I push it past a certain point the engine bogs down and feels like it wants to die. Could it be the o2 sensor? Link to comment Share on other sites More sharing options...
Nefarious Posted July 21, 2013 Share Posted July 21, 2013 I would think the maf getting wet over the o2... Link to comment Share on other sites More sharing options...
rwd5021 Posted July 21, 2013 Author Share Posted July 21, 2013 I'll have to check that next time it happens, but I don't think the water splashes up quite that high. Link to comment Share on other sites More sharing options...
rwd5021 Posted July 21, 2013 Author Share Posted July 21, 2013 Could the o2 sensor cause a similar problem tho? Link to comment Share on other sites More sharing options...
snowboard419 Posted July 22, 2013 Share Posted July 22, 2013 I would not think an o2 would cause that problem but next time it happens try unplugging the sensor, the engine will run in open loop where it does not use the o2 for calculating air fuel mix and if that is the problem the engine should start to run relatively well. It might throw a code. I would think water getting under the distributor cap would be a more likely cause. But I have not had this problem before so I could not say for sure. Is your check engine light on ? Link to comment Share on other sites More sharing options...
rwd5021 Posted July 22, 2013 Author Share Posted July 22, 2013 No check engine light. I'll try both of those, thanks guys! Link to comment Share on other sites More sharing options...
Kyle94 Posted July 22, 2013 Share Posted July 22, 2013 My plugs wires are shot and when I splash about my truck runs like Ass... Until it's dried out. Then it goes back to normal. Link to comment Share on other sites More sharing options...
ahardb0dy Posted July 23, 2013 Share Posted July 23, 2013 Try spraying the spark plug wires with a spray bottle filled with water, while it's running at night, if you have a bad wire you should be able to see the arc if it is arcing against metal and hear the clicking. Link to comment Share on other sites More sharing options...
