'91 SE Pathfinder
I bought this Pathy for 700 bucks. Seems like a great deal, clean inside and out, motor sounded healthy and drives fine. The gauges didn't work and from some info I found on here I replaced the voltage regulator behind the dash, replaced the broken door handle, corner running light up front, all taken off the '90 D21 I had ripped off 2 weeks earlier and brought back by the CHP with a blown out clutch plate, windows broken, graffiti all over the interior, door panels ripped off to get to the speakers, etc. I sold it as parts for 400.00. The PO couldn't remember when the TB was done last so I replaced it along with the WP, thermostat, bypass hose..... So everything is working well except the rear windows don't roll up and down. You can hear the motor doing its job but regulator not attached to window. I took one apart and found that the tab that is captured in the regulator had broken out of its slot. I know the regulators are pretty cheap but I was thinking some creative JB Weld would work. Anybody tried to fix this issue without buying new regulators?
  • Replies 54
  • Created
  • Last Reply
Top Posters In This Topic
Whoops! Typo!
Very nice! I've never tried to JB weld it. I've always preferred to just buy new regulators. But if you do JB weld it, I'd love to know how well it works!
Auto or manual?
Auto. It shifts smooth and reverse feels good but I still wanna throw a new filter in it and new fluid. I'll try the JB Weld just for kicks, gives me something to post
Thanks! Just adjusted the TBs today, don't know how much adjustment is left but took it up an inch. There are several JGCs at the local P&P so will be yarding out some springs soon. It looks like this thing never saw a rock, not a dent, nick, scrape underneath. I look forward to using all this new knowledge I am gleaning from everyone here. Thanks all!!!
Yeah, I read that. I haven't even driven it yet so I can't wait to see how it feels. I had a very slight ( almost unnoticeable) shimmy at freeway speeds. I hear most alignment places can't get Pathys right anyway...
I'm sure it will be a bit stiffer but nothing major, looks better without the front lean lol all it really does is tilt your wheels, when I did my last pathy I had to raise it 3inchs, it was a tad noticeable, but I took it to a shop the next day and did a rotation and alignment plus my tires were less than 10k old. If you didn't bump it up a lot and you got older tires, I wouldn't worry about it until you get new tires, just be warned!
Brand new tires(on the front) came with the 700 dollar deal..... Only went up an inch, if that. Just wanted to try out the procedure. Suspension was flat and even when I started, I didn't want to go up too much until I got the rear springs. Just looked it up on Pick&Pull website, springs are 21 bucks a piece and a tranny cooler off a Exploder for 17......
Oh then you got nothing to worry about, your on a good road, protect the autos, I went threw 2 before I did an auto to standard swap, never installed a cooler thou, I just like standards better anyways. It will look nice with the little lift, looking forward to some pictures!
Place on Hartnell next to Harbor Freight. Try them. He aligned my old bagged Hardbody and took the time to get it right. My buddies Pathfinder and now mine have been through there and we've been happy.
Hey guys,
I went to Pick&Pull and got a tranny cooler. Most of the Exploders had a little tube and fin cooler but I found a one that had a pretty big plate cooler. Score. But when I got to a JGC to yard out the springs, it looks like a PITA. Can I take off the bottom capture for the spring, use a spring compressor and take it out that way? Other than that it looks like I have to get into the engine compartment and disassemble half of the crap in there to get to the top mount and release it that way. Before I BMA trying to get these springs I wanted to ask the pros if there was an easy way.
After I clean up this cooler I will post a pic of it.
Here is the cooler I found today at Pick&Pull. It does not look stock of the other ones that I saw, the others were tube and fin types. Is this aftermarket? There is no thing as too big right? It is 11"X71/2"... If Mount it upright I want return at top? How about mounting?
There is such a thing in terms of too big to fit between the grill and rad. Other than that, should really be an issue AFAIK.
As far as mounting, it may have "in" and "out" marked. Orientation doesn't matter I think.
The mount looked factory but this is considerably more substantial than off the other Exploders. I am guessing factory upgrade? I saw no in or out so I won't worry about feed and return, barbs are pointing down so not worrying about air pockets either...
It's super easy to pull front JGC springs...only takes 15 min once the vehicle is off the ground. Just let the front axle drop by lifting up the frame. Then u unbolt the lower shock bolts, the sway bar end links, and the lower spring lock clip. Very very simple
?? Uh, what is your version of Difficult?
