Precise1 Posted June 28, 2013 Share Posted June 28, 2013 Posting this for a friend, so Doug says thanks in advance. When he uses the automatic roll up feature on his 2001 Pathy, the front drivers window will go all the way to the top and then roll back down about 4". I have not seen this in action, but he was pretty clear in the message he left. I looked it up and the FSM says to pull the door pannel (good time to look for anything loose, broken, etc) and then... RESET PROCEDURESNABT0029S02After installing parts, proceed as follows:1. Close the door window completely.2. Press the reset switch and open the door window completely.3. Release the reset switch. After making sure the reset switchhas returned to the original position, close the door windowcompletely.4. The limit switch is now reset.CAUTION:Be sure to manually open or close the door window. (Do notuse the automatic open-close procedures.) Makes sense to me and seems pretty straight forward, but does anyone have any experience or input to share? Thanks, B Link to comment Share on other sites More sharing options...
Alkorahil Posted June 28, 2013 Share Posted June 28, 2013 I was about to say there is a reset proceedure for the windows. Seems like you found it! Link to comment Share on other sites More sharing options...
Precise1 Posted June 28, 2013 Author Share Posted June 28, 2013 Yep! Thanks Bud... I talked to him about it last night and he said he might just take it to a mechanic. My response was "It's your truck, Moneybags..." B Link to comment Share on other sites More sharing options...
Towncivilian Posted June 29, 2013 Share Posted June 29, 2013 It takes all of five minutes to remove and replace the door panel, and the button is easily accessible after removal. There is even a pictorial guide on NICO http://forums.nicoclub.com/how-to-remove-door-trim-on-1999-qx4-t445467.html'>here. Maybe that would change his mind? Link to comment Share on other sites More sharing options...
Precise1 Posted June 29, 2013 Author Share Posted June 29, 2013 I already told him that it looks pretty damn simple to me, but I suspect he is being lazy. No worries, the last thing I do is force my help on someone who doesn't want it... B Link to comment Share on other sites More sharing options...
RedPath88 Posted June 29, 2013 Share Posted June 29, 2013 Please post the end results of this... aka, the bill! Link to comment Share on other sites More sharing options...
Trogdor636 Posted June 29, 2013 Share Posted June 29, 2013 If its not a really close friend, I'm always happy to let them take it to a shop. Less work for me! Link to comment Share on other sites More sharing options...
