Limited Slip, How to Tell?
trundle
How do you know if a used Pathfinder has a limited slip in the rear. I understand it came on some of the SE models with the tire carrier on the rear. I am most interested in 97's through 99's. I know I could take it out into the snow and wail on it and see if a tire spins out or something like that or checking the vin #, but was hoping there woudl be a way to tell just by looking at the dif. Thanks in advance.
Mine says "Use LSD oil only" on the differential case. I can't remember if it's a sticker or if it's right on the metal. I haven't had it very long, and didn't know when I bought it that it was LSD. But I noticed it when I was looking underneath.
In the 96-97 years the following models had LSD:
XE 4x4 with Sport Pkg
LE 4x4
SE 4x4 with Off Road Pkg
Another way you can tell is by the ID marks stamped in white paint on the top of the rear differential. The ID mark will start with 2 letters, this table defines them:
CR 48:11 4.363
CT 48:11 4.363 LSD
CV 51:11 4.636
CX 51:11 4.636 LSD
