Mknabb335
About Mknabb335
  • Birthday 11/11/1984
    1997 Pathfinder SE. Black, beige cloth(soon to be leather), S-Roof, TJM t-15 bull bar, 2"ac w/ranchos, 31x10.50 bfg a/t, warn hubs, new axel seals and rear bushings, cross drilled rotors, audio bahn subs, amps and caps, infinity door speakers.... more to come
Contact Methods
  • AIM
    mknabb335
  • Website URL
    http://
  • ICQ
  • Interests
    4wheel drives, dirt bikes, camping, school, football
Mknabb335's Achievements
  1. I had a similar problem on my 5000's. A few washers from ACE hardwear took care of that problem.
  2. I am busy as heck with school and work but if I cant get back here on time my email is Mknabb335@aol.com
  3. I have some cross drilled, slotted rotors for a 99.5-02 r50. Bought for my 97, and the seller neglected to tell me they were for a later r50. But i will more than happily sell them to you.
  4. Does anyone know if the front brake calipers off of a 99.5-2002 R50 would fit on my 97 R50? Thanx.
  5. Ok, sounds good so class 8 is the way to go. Thanks
  6. are you getting rid of your chrome end caps on the rear bumper?
  7. 88pathoffroad: No i didnt throw away anything, it is all bagged, separated and numbered. Some of the bolts broke, stripped or had to be grinded off and i figured I would go with all new stuff since I needed a few new ones anyway. What Mr. Pickles suggested was my plan, to go by what my manual called for. But now from the input I have gotten I will make do with what Ace had availible. Thanks for the info guys, has helped me quite a bit.
  8. mine have a little bit of play, if I pull on them. I figure as long as they are screwed in tight it will be ok.
  9. I have been putting on the AC 2 inch lift and am putting everything back together. My haynes manual I bought for the patthy says that the manufacturer calls for many of the bolts and nuts to be replaced. So I went to my local ACE hardware and did find much of anything. Adavanced Auto Parts said they didnt have anything but said they could mix and match peices to work, this would be ok I guess but I would rather have oem equipment. All I can think now is that I have to go down to the nissan dealer and get all my bolts and nuts from them. If anyone has some info, please help me out here. I have been working on my pathfinder for 4 months now and am really really ready to have it done and finally drive it. By the way what I need is Upper and Lower contol arm (bolts, nuts, and washers), Panhard bar (bolt and nuts), Shocks (bolts and nuts), Struts (upper mouting nuts, strut to knuckle nuts, piston nut).
  10. Crap... I wanted those bad. If I was not at work mabey I would have out bid you. I am glad to see someone on here got them though. Hope another pair pops up. Tell me how they are when you get them on vengeful.
  11. I got the third to last t-15 from 4x4 connection and that was in April. I wanted the t 17 but they had already discontiued it. They had no black so I got the aluminum version. Wanted black but, the polished aluminum looks pretty good since my pathfinder is black.
  12. If it is a cherokee it is a unibody. Therefore it will not have a body lift but all suspension. if you need parts I have an 89 cherokee with a 4.0 inline six and a 5speed. It also has a 3 inch lift.
  13. I am going through the same process and those bolts were a b!tch. I cut mine off. I am replaceing upper and lowers and have to buy new upper control arm mounts along with a new lower control arm. All I see is $ going out the wallet. At least I have a buddy who works in a machine shop and is going to press the bushings for free.
  14. Did you have to take off your flairs to get the 33's to fit w/o rubbing? I am debation on if I should keep mine or not. I have the ac lift and currently going to run 31's untill I can get 5 32 bfg mt kms. By the way you have a nice Pathfinder.
  15. I wonder how much lift that is and if there is rubbing?
