Perris Posted October 10, 2012 Share Posted October 10, 2012 My transmission is getting tired after 275,000 miles. It grinds going into 3rd and 4th. Also it falls out third when I let off the throttle. In addition it falls out of 1st sometimes when starting from a complete stop. First choice is to get it rebuilt (bearings and syncros). Second choice is to get a used transmission out of a junk. My question is: Will 86-95 transmission bolt straight in to my 88 pathfinder? Also will a trans out of a V6 hard body work? Also, is a later model transmission more desirable because they hold more fluid? Link to comment Share on other sites More sharing options...
Kyle94 Posted October 10, 2012 Share Posted October 10, 2012 96-99 vg33 pathy trans will work too. as will the hardbodys tranny. has to be 4wd though. if you go 96-99 pathy you get a higher fill plug which eliminates the TSB that is on the 1987-1995 tranny. Link to comment Share on other sites More sharing options...
Towncivilian Posted October 10, 2012 Share Posted October 10, 2012 96-97 D21 trans also has the corrected fill hole location. This post has more info about using a newer manual trans. Link to comment Share on other sites More sharing options...
Trogdor636 Posted October 10, 2012 Share Posted October 10, 2012 96-97 D21 trans also has the corrected fill hole location. This post has more info about using a newer manual trans. 96-97 V6 Hardbodies do not exist. Emissions reasons. Link to comment Share on other sites More sharing options...
Harbinger Posted October 10, 2012 Share Posted October 10, 2012 At least in the USA they didn't. I've found listings for canadian 96-97 V6 trucks however. Link to comment Share on other sites More sharing options...
Trogdor636 Posted October 10, 2012 Share Posted October 10, 2012 (edited) Thats probably correct, the VG30E was not OBDII ready, so 96-97 was a 4 cylinder festival for Hardbody trucks here in the US. He said miles, I assumed he was in the US. Edited October 10, 2012 by Trogdor636 Link to comment Share on other sites More sharing options...
NWT87PATHY Posted November 10, 2012 Share Posted November 10, 2012 3.5l mates to. Vg30 M/T? Link to comment Share on other sites More sharing options...
Kyle94 Posted November 10, 2012 Share Posted November 10, 2012 Where was that said? The 3.3L (VG33E) bolts to a vg30e trans, and vg33e trans bolts to a vg30 engine... but not the 3.5L to my knowledge. Link to comment Share on other sites More sharing options...
NWT87PATHY Posted November 10, 2012 Share Posted November 10, 2012 (edited) Ha! Search brought me to trans compatiblity. I came accross a 03 pathy rightoff for 500. Thing is mint minus the front bumper rad support and headlights. Want the interior and heart beat for my 2door. Then its Ztune time! Edited November 10, 2012 by NWT87PATHY Link to comment Share on other sites More sharing options...
Slartibartfast Posted November 10, 2012 Share Posted November 10, 2012 (edited) I'd like to see a 3.5l WD. VG30E was not OBDII ready But the VG33 R50s are OBDII, right? Isn't the engine (minus the intake) basically the same? Edited November 10, 2012 by Slartibartfast Link to comment Share on other sites More sharing options...
silverton Posted November 10, 2012 Share Posted November 10, 2012 Anything 96 and newer is OBD2. a OBD2 vg30e was used in the nissan quest/mercury villager. Link to comment Share on other sites More sharing options...
NWT87PATHY Posted November 10, 2012 Share Posted November 10, 2012 (edited) Sorry for the thread jacking .. Has anyone one hurd of a adaptor plate of sorts to get my trans on the back of a VQ block? Possibly just a bellhouse swap to my gear box? I do have a Bl so if i end up using engine and trans i have the clearance to get it under my truck. But all bs aside if my gearbox is good enough for a TT VG30 then it should be the best choice for any HD application.. Right ? Edited November 10, 2012 by NWT87PATHY Link to comment Share on other sites More sharing options...
Slartibartfast Posted November 10, 2012 Share Posted November 10, 2012 Very few companies make Pathy bits, so I doubt it. I'd stick with the trans the VQ came with if possible, it should be a lot beefier. Link to comment Share on other sites More sharing options...
NWT87PATHY Posted November 12, 2012 Share Posted November 12, 2012 Very few companies make Pathy bits, The horrible truth right their! Lol. Thats why i had to start teaching myself fabing. Thank you Nissan! Link to comment Share on other sites More sharing options...
