codes 21 and 32
anyone had these two codes pop up together consistantly on a cali emissions pathy? im having trouble tracking down the problem after these parts have been replaced. the codes just keep coming back.
Ignition signal and EGR? :scratchhead:
If new sensors don't solve the problem, either there's a problem with the harness or something's wrong with what the sensors monitor. I'd check the plugs first, make sure they're not corroded
its fixed. the egr port was clogged where it meets with the mixture heater plate. not much room in there at all. bad design. ignition code has vanished too. strange.
never had this issue with my 87 hb. but i also maintained it alot. i used the egr valve from my hb and it was nice and clean. i just wasnt sure how common it was.
