kefferjoe Posted July 10, 2012 Share Posted July 10, 2012 hi i need to remove a portion of the passengetr front wheel well the piece that i need is in the front of the wheel well and is partially attached to the core support...after examinig it for a bit it looks like the rest of the portion i need is attached with some sort of silicone glue. Am i overthinking this by supposing that this should be harder to remove than it really is or is it really just glued in there with a few spot welds on one side. Link to comment Share on other sites More sharing options...
Slartibartfast Posted July 10, 2012 Share Posted July 10, 2012 Not familiar with the part, but... that's probably seam sealer you're looking at. Doesn't mean it is or isn't welded underneath, but I've never seen it used just as an adhesive. In fact on my WD the seamsealer's one purpose seems to be rust creation... every time I strip some off I find rust under it! Link to comment Share on other sites More sharing options...
Trogdor636 Posted July 10, 2012 Share Posted July 10, 2012 If its anything like a WD21, the entire inner fender is one piece. Its spot welded at the core support and the firewall most likely. Link to comment Share on other sites More sharing options...
pathfounder Posted July 11, 2012 Share Posted July 11, 2012 The wheel wells are structural on an R50. Link to comment Share on other sites More sharing options...
devonianwalk Posted July 11, 2012 Share Posted July 11, 2012 Are you speaking of removing the inner plastics? That is all that is removable on our R50's. Link to comment Share on other sites More sharing options...
kefferjoe Posted July 11, 2012 Author Share Posted July 11, 2012 Well panel under the front plastic. It has the battery stand attached to it. I think what's happening is the panel over laps another panel and these panels are either "glued" together or they are spot welded and "glued" together I'll try and post pictures of everything I'm doing tomorrow when it's light out and I can get some decent pictures Link to comment Share on other sites More sharing options...
