DryBear Posted June 25, 2012 Share Posted June 25, 2012 So my 87 I4 2 Door Pathfinder came with 30x9.50R15 tires mounted on 15x9.5" wheels. I thought that was an odd size to have on my Pathfinder, but there didn't seem to be any problems, except for wear. So I went to the local Big-O-Tires to get some new 30x9.50R15 tires, and the mechanic says that the 30x9.5 tires shouldn't fit on my 9.5" wheels, and should at most go on an 8" wide wheel. Obviously, I've got those size tires on my wheels, and they hold air fine, so Is this guy full of crap, or what? In any case should I stick to the 30 tires or go with a 31 size tire? Link to comment Share on other sites More sharing options...
ahardb0dy Posted June 25, 2012 Share Posted June 25, 2012 Don't recall any wheels 9.5" wide, possibly they are 10's? I would agree with the tech, yes the tires will mount on your wheels but having a 9.50 tire on a 10" wide wheel is going to pull the sidewalls way out, besides giving the bubble look it leaves the sidewall out there where they can easily be damaged. I would expect a 9.50 to be mounted on a 7" wide wheel. Even 10.50's on a 10" would be pushing it. Of course some may disagree with me, I'm speaking as being a former tire mounter in a 4x4 shop for many years. Link to comment Share on other sites More sharing options...
nismothunder Posted June 26, 2012 Share Posted June 26, 2012 You could possibly see increased edge wear, besides that if you dont off road I see no problems. Link to comment Share on other sites More sharing options...
DryBear Posted June 26, 2012 Author Share Posted June 26, 2012 Thanks for the feedback - looks like I will go with the 31x10.5s to be safe. Link to comment Share on other sites More sharing options...
Precise1 Posted June 26, 2012 Share Posted June 26, 2012 Tires should always be wider than the rim, around 20-30% is a good average but every tire is slightly different. Find the tire you are interested in and then go to the manufacturer web site where they should have the recommended wheel widths for that particular tire model and size. B Link to comment Share on other sites More sharing options...
tmoore4512 Posted June 26, 2012 Share Posted June 26, 2012 I agree that they will work, but you should definetly go with a wider tire. I run a 33x12.5 on 10 inch wheels (that B told me about), and they work great. Then again the choice is up to you.... Link to comment Share on other sites More sharing options...
