andreus009 Posted September 11, 2012 Share Posted September 11, 2012 Well just spoke to salesman at Amazon hose, doesn't look like I will be getting hoses made from them. First the guy told me the braided SS hoses with the teflon lining over time the teflon breaks apart so that doesn't sound good Well, I know this is a late reply but its not a teflon lining. The whole hose is teflon with a stainless steel braided jacket (see H243 on page 50 of their online 'paper' catalog). The teflon hose has temp rating from -100F to +450F which is why I went this route....the hoses run close to the headers in my case. The stainless helps with abrasion and reflects heat also. I have had them on a few years now and not had a problem so far. I explained to the guy at the store exactly what I was doing and he didn't mention any concern about the hoses breakdown over time. Anyways, I'm sure there are cheaper suitable alternatives. Link to comment Share on other sites More sharing options...
andreus009 Posted September 11, 2012 Share Posted September 11, 2012 i can't remember if i asked this question or not, but is it better to but a relocation kit or make my own...and where should i get the kit, i looked on ebay but what comes up doesn't look right...where should i get it? or if i piece it together where should i get the parts from? Pretty sure this is the one I used http://www.summitracing.com/parts/HDA-291/?rtype=10 Link to comment Share on other sites More sharing options...
Felipe4x4 Posted September 12, 2012 Share Posted September 12, 2012 that looks reasonable...and self explanatory...thanks for the info...this will be my next purchase...plus my oil change...then my headers... Link to comment Share on other sites More sharing options...
RF600 Posted September 14, 2012 Author Share Posted September 14, 2012 That is the kit I used. If you go cloth braided it is easy to work with. I put an extra heat sleeve over my hoses. I had rubber lines made. Link to comment Share on other sites More sharing options...
andreus009 Posted September 14, 2012 Share Posted September 14, 2012 I used this heat sheath/sleeve on my fuel lines: http://www.designengineering.com/category/catalog/dei-cycle/line-sleeving/heat-sheath-aluminized-sleeving Link to comment Share on other sites More sharing options...
Desert89 Posted September 15, 2012 Share Posted September 15, 2012 (edited) For those shopping for ready made kits Don't but the Transdapt kit. I got mine from 4x4parts.com,SKU: PPOK11134337. It is made of cast pot metal and has no QC on the finish. O-ring groove was not machined I had to clean up the female threads to esure I wouln't have flakes of metal in my oil system. Definately not the quality I would expect for the price. Edited September 15, 2012 by Desert89 1 Link to comment Share on other sites More sharing options...
Felipe4x4 Posted September 16, 2012 Share Posted September 16, 2012 this is all good info guys...thanks... Link to comment Share on other sites More sharing options...
ahardb0dy Posted September 16, 2012 Share Posted September 16, 2012 I bought the transdapt single filter mount and adapter, separate, no problems at all with the machining or the 2 parts at all. This is the second set I have bought, first one was probably 20 years ago (still have it but it is a dual filter mount), no problem with the old parts either just did not want to run dual filters this time and needed a new O-ring for the adapter, was almost as cheap to buy the new adapter than just the O-ring so I did. You may have just got a bad one. Most if not all of the mounts and adapters are cast unless they say they are billet. Link to comment Share on other sites More sharing options...
Felipe4x4 Posted October 26, 2012 Share Posted October 26, 2012 just put my adapter today...going to test it out make sure the spot is ok before i hook it all up...ill post pics soon after... Link to comment Share on other sites More sharing options...
odek1974 Posted November 24, 2012 Share Posted November 24, 2012 where you can buy the oil relocation filter for 1994 nissan pathfinder? because I keep changing the starter every six months and I am sicked and tired doing this dilemma.! Link to comment Share on other sites More sharing options...
ahardb0dy Posted November 24, 2012 Share Posted November 24, 2012 Lot of places, I bought my adapter and filter mount from http://www.summitracing.com/ they sell the hoses too or you can have the made locally Link to comment Share on other sites More sharing options...
Felipe4x4 Posted November 28, 2012 Share Posted November 28, 2012 (edited) where you can buy the oil relocation filter for 1994 nissan pathfinder? because I keep changing the starter every six months and I am sicked and tired doing this dilemma.!summit racing is a good place...not to expensive and you can even use a nissan oil filter with it...now finding a spot is more of a tuffy... ---- i tried to post a pic but i couldnt figure it out...i basically put my filter relocater in the right wheel well, but i made a bracket for it so it acctually sits inside the engine compartment close to the power steering pump...so it clears the wheel and the pump and i can still put the rubber cover back on and its all nicely tucked away... Edited December 3, 2012 by RedPath88 Merged Posts Link to comment Share on other sites More sharing options...
RF600 Posted November 28, 2012 Author Share Posted November 28, 2012 Photobucket is a good site for storing pictures. They have upgraded an now have editing features. Pretty slick. Link to comment Share on other sites More sharing options...
